    Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod.
    intotubes
    intotubes
    Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod. Empty Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod.
    Post by intotubes Fri Feb 15, 2019 10:05 pm
    I just installed the Dynakitparts bias/balance control kit in my ST-70. I am using 6L6GC tubes. I can balance them OK but can only bias down to .7 or .8 volts as measured in the octal socket. Do I need to change the bias resistors for these tubes?
    -Mark
    Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod. Empty Re: Can't bias 6L6 low enough in ST-70 with Dynakitparts bias mod.
    Post by Guest Fri Feb 15, 2019 10:41 pm
    intotubes
    intotubes
    Post by intotubes Fri Feb 15, 2019 11:27 pm
    Thanks. I'll give it a shot.
    intotubes
    intotubes
    Post by intotubes Sat Feb 16, 2019 12:27 am
    Better but still too high. I have to drop the main voltage down to 100V to get .38V bias. I guess it's time to remove the bottom and check voltages. I have an assembly manual but I was hoping this was an easy mod.
    Oh well, I guess that's why this hobby is interesting - troubleshooting.
    intotubes
    intotubes
    Post by intotubes Sat Feb 16, 2019 2:13 pm
    I replaced the selenium rectifier with a diode and found on another post that I should reduce the two 10K resistors to 5K. I did so then put the 5AR4 back in. I can now get the bias down to 45ma at 115V main voltage. If a little's good, a lot's better so I paralleled another pair of 5K's in. One side will go as low as 32ma but the other side won't go lower than 42ma. I think it has more to do with the tubes now since the bias supply is the same for both sides. So for my sound test I guess I will bias both sides to 42ma.
    I was hoping to use my supply of 6L6GC's but I may end up buying a quad of EL34's.
    Update. Connected a pre and speakers. Sounded OK. Checked bias and balance again after things had warmed up. Tweaked the balance a bit. Bias current now reading 32ma. Lots of adjustment now. Moved up to 40ma. Sounds good. Still need to replace the can cap.
    I found lots of info here, just had to modify me search a little.
      Current date/time is Tue Mar 19, 2024 12:34 am
