I have seen a few posts about this. Is there anyone that has the replacement procedure to Silicon Diodes in a little more depth? I will also replace Caps 1000uF 50V should be good? I have the schematic. Is it just as easy as putting the Silicon Diodes where the Selenium diodes go in the schem? THX
Replacing selenium rectifier on PAM
peterh- Posts : 1823
It should be that easy. Mechanically you might need a solder strip.
GP49- Posts : 792
You really could very probably get away with soldering a silicon diode across the old selenium rectifier, using it as a tie-strip. The silicon is lower resistance so the presence of the selenium rectifier, especially if it has gone high-resistance (that's what happens to nearly all of them when they get old), won't make any electrical difference.
bubbasweet- Posts : 95
Anyone know if any added resistance is needed as only .7 across a diode? or just the IN4007s. Also do any of you use 2 diodes per side or is one good enough. I suppose I am over thinking.
Tubes4ever- Posts : 167
One diode is enough.
