    150v or 250v SCA 35
    Paul229
    150v or 250v SCA 35
    Post by Paul229 on Sat Mar 26, 2016 2:04 am
    SCA 35
    Replaced the two Aerovox caps in power supply
    But ran a problem second Capacitor
    C 23 Lug
    (1) 320v
    2 250v
    Pin 1 is connected with a 22K to pin 2 of the aerovx 50/50uF
    Giving it 150v
    Schematics says 250v
    Which one is right ...the 22k resistor in there.....to follow- or the schematics...?
    Should the voltage be 250v or 150v.....?
    Re: 150v or 250v SCA 35
    Post by peterh on Sat Mar 26, 2016 4:16 am
    Paul229 wrote:SCA 35
    C 23 Lug
    (1)  320v
    2    250v
    Giving it 150v
    In well-debugged schematics ( and sca35 is well debugged ) follow the schematics. Always.
    If the circuit is changed you are on your own. The way i would recommend in sca35 is
    not to replace the caps but install an EFB board instead. This procedure is well documented
    and constitutes an add-on to the schematics.
    evoroadster
    Post by evoroadster on Sat Mar 26, 2016 12:21 pm
    Just go with the EFB update from Dave. You won't be sorry.
    http://tronola.com/html/daves_store.html
      Current date/time is Mon May 21, 2018 2:52 am
