    TUBE SOCKETS
    extremegv1
    TUBE SOCKETS Empty TUBE SOCKETS
    Post by extremegv1 on Thu Mar 04, 2010 10:35 pm
    Is THERE A differance in tube sockets? what are the best to use on a st-70.
    TUBE SOCKETS Empty Re: TUBE SOCKETS
    Post by Bob Latino on Fri Mar 05, 2010 4:39 pm
    extremegv1 wrote:Is THERE A differance in tube sockets? what are the best to use on a st-70.
    On all Dynaco amps with octal sockets you need "bottom mount" sockets that fit a 1 1/8 inch hole with a 1 1/2 inch screw mount center.
    Ceramic sockets - Personally I don't like these because their white color (IMHO) doesn't look as good as a black socket. Most of these are from China and are cheaply made. Ceramic sockets also have no "give" and unless you are careful you can sometimes break the center guide pin on an octal tube withdrawing a tube from a ceramic socket.
    Black Celanex sockets - I like this because the black matches the original color of the Dynaco amps and they have floating pins which makes it easier to insert a tube. These do not have a grounding tab but Kevin at Dynakitparts includes a grounding tab with every Celanex tube socket he sells. These are the same sockets that I use in kit and wired amps.
    Celanex octal tube sockets at Dynakitparts
      Current date/time is Mon Jan 27, 2020 12:45 am
