    Replacing selenium rectifier on PAM
    bubbasweet
    bubbasweet
    Replacing selenium rectifier on PAM Empty Replacing selenium rectifier on PAM
    Post by bubbasweet Sun Mar 27, 2016 9:55 pm
    I have seen a few posts about this. Is there anyone that has the replacement procedure to Silicon Diodes in a little more depth? I will also replace Caps 1000uF 50V should be good? I have the schematic. Is it just as easy as putting the Silicon Diodes where the Selenium diodes go in the schem? THX
    Replacing selenium rectifier on PAM Empty Re: Replacing selenium rectifier on PAM
    Post by peterh Mon Mar 28, 2016 2:34 am
    It should be that easy. Mechanically you might need a solder strip.
    Post by GP49 Mon Mar 28, 2016 11:07 pm
    You really could very probably get away with soldering a silicon diode across the old selenium rectifier, using it as a tie-strip.  The silicon is lower resistance so the presence of the selenium rectifier, especially if it has gone high-resistance (that's what happens to nearly all of them when they get old), won't make any electrical difference.
    bubbasweet
    bubbasweet
    Post by bubbasweet Tue Mar 29, 2016 1:16 am
    Anyone know if any added resistance is needed as only .7 across a diode? or just the IN4007s. Also do any of you use 2 diodes per side or is one good enough. I suppose I am over thinking.
    Tubes4ever
    Tubes4ever
    Post by Tubes4ever Thu Mar 31, 2016 10:19 am
    One diode is enough.
      Current date/time is Thu Mar 28, 2024 5:10 am
