    ST-70 local to me
    evoroadster
    evoroadster
    ST-70 local to me Empty ST-70 local to me
    Post by evoroadster Sun May 15, 2016 2:07 am
    We don't get too many tube amps popping up on Craigs List here on Oahu but here is one:
    https://honolulu.craigslist.org/oah/ele/5545763828.html
    I have never seen a cover like this over the circuit board. I am thinking of looking at it tomorrow. Opinions welcome.
    ST-70 local to me Empty Dynaco ST-70A?
    Post by stewdan Sun May 15, 2016 10:05 am
    Hi --- I believe there was a factory built ST-70A that had a metal cover over the PCB and had a different color PCB (Light Green??). I saw a picture of one, once, when the Radio Shack Catalog listed Dynaco Products back in the late 1960's or early 1970's??
    ST-70 local to me Empty Dynaco 70A
    Post by stewdan Sun May 15, 2016 10:09 am
    Hi again --- just looked more closely at your pictures --- lower left corner of the left and middle pictures say "70A".
    evoroadster
    evoroadster
    ST-70 local to me Empty Re: ST-70 local to me
    Post by evoroadster Sun May 15, 2016 12:29 pm
    Thanks for the info. I found a very nice write-up of the ST-70A here:
    http://www.audiocircle.com/index.php?topic=60831.0
    daveshel
    daveshel
    Post by daveshel Sun May 15, 2016 3:30 pm
    That's in great shape. I'd go for it. Even though I believe the ST-70 is overrated compared to the ST-35 or the MK-III, that's a steal for a clean factory wired unit in an obscure market. If you're not nuts about the sound, you should be able to easily recoup your investment.
    evoroadster
    evoroadster
    Post by evoroadster Wed May 18, 2016 4:26 pm
    So, the question is: Do I go for this one and update it with a VTA board and cap can or just go ahead with my original plan of building one of Bob's VTA-70 kits? Around $1100 with options with Bob's kit vs $750 all in for the Craigslist amp.
    Post by Bob Latino Wed May 18, 2016 6:26 pm
    evoroadster wrote:So, the question is:  Do I go for this one and update it with a VTA board and cap can or just go ahead with my original plan of building one of Bob's VTA-70 kits?  Around $1100 with options with Bob's kit vs $750 all in for the Craigslist amp.
    Some of the original Dynaco ST-70's date as far back as 1959 .. That amp could well be 50+ years old. About the only thing that still stands the test of time are the output transformers. Everything else on the original Dynaco ST-70 was a compromise so that they could sell the kit or wired amps at relatively low prices. Older original Dynaco ST-70's are not a good amp to be used as a "daily driver" unless they are completely rebuilt. If you do purchase that amp, plan on sinking some $$$ into the amp if you intend to use the amp on a daily basis. Read at the forum link below that compares an original Dynaco ST-70 to new VTA ST-70.
    Comparison > original Dynaco ST-70 and a VTA ST-70
    evoroadster
    evoroadster
    Post by evoroadster Wed May 18, 2016 8:48 pm
    Thanks Bob, that is the way I will go. I have no real desire to save the ST-70A as a museum piece nor do I really want to tear it up to bring it into the 21st century. I already went through that with a SCA-35.
      Current date/time is Fri Mar 29, 2024 12:44 am
