+10
Hops
MechEngVic
buschfsu
WntrMute2
RockyAM
14 posters
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information Empty VTA ST-70, VTA ST-120 and VTA M-125 amplifier information
    Post by Bob Latino Fri May 20, 2016 12:06 pm
    After extensive listening at various bias settings for ALL the VTA amps I am now recommending slightly lower bias settings for some of the VTA amps. These recommendations give no changes in the sound quality of the amps but will noticeably extend tube life. The listening was not only done by me but was also done by a number of VTA amp customers.
    VTA ST-70 with EL34 or 6L6 output tubes > recommended bias setting is .40 VDC per each output tube which gives a bias current of 40 milliamps per each output tube.
    VTA ST-70 with KT66 or KT77 output tubes > recommended bias setting is .45 VDC per each output tube which gives a bias current of 45 milliamps per each output tube.
    VTA ST-70 with 6550 or KT88 output tubes > recommended bias setting is .50 VDC per each output tube which gives a bias current of 50 milliamps per each output tube.
    VTA ST-120 with 6550, KT88 or KT120 output tubes > recommended bias setting is .50 VDC per each output tube which gives a bias current of 50 milliamps per each output tube.
    VTA M-125 with 6550, KT88 or KT120 output tubes USING TWO OUTPUT TUBES PER AMP > recommended setting is .50 VDC per each side which gives a bias current of 50 milliamps per each output tube.
    VTA M-125 with 6550, KT88 or KT120 output tubes USING FOUR OUTPUT TUBES PER AMP > recommended setting is 1.00 VDC per each side which gives a bias current of 50 milliamps per each output tube.
    All the user manuals will be changed to reflect the new bias recommendations ...
    VTA ST-70 KIT assembly video below. This KIT video was done by VTA ST-70 amp builder Rick Green from FL. The video does not show all the wiring steps but does give a good idea of how the VTA ST-70 amp is assembled. Note that this amp has the older two post binding posts. All the new VTA amps (kit or wired) have THREE post binding posts and may be set up for any TWO impedances (4 and 8 ohm, 4 and 16 ohm, 8 and 16 ohm).
    Review Home Theater and Hi-Fi  > The VTA ST-120
    Review Home Theater and Hi-Fi > The VTA M-125
    Another VTA M-125 review > VTA M-125 review from 2015
    VTA Tube Amp Kits Facebook page > Facebook > VTA Tube Amp Kits
    VTA ST-70 amp wiring photo below
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information ST-70-photograph-new-K42-Y
    VTA ST-120 amp wiring photo below
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information ST-120-Rick-Green-TEXTSIDEWAYS7-4-20-normal
    VTA M-125 amp wiring below
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information M-125-interior-wiring-2
    ADDED on 3/5/20 > In certain parts of the USA and Canada line voltages can be higher than normal. While 120 VAC is supposed to be the norm, customers have reported to me voltages in the 122 to 125 VAC range. These higher than normal line voltages can cause shorter than normal tube life in your tube amp > especially the rectifier. In order to counteract this issue, all the VTA ST-120 and VTA M-125 monoblock amps will now come with DUAL PRIMARY connections. If your line voltage is normal (below 121 VAC), you use the standard connection. If your line voltage is 121 VAC or higher, you use the alternate connection which will drop the voltages on the secondary windings by about 2 1/2 %. Example > If your line voltage is 124 VAC, using the alternate connection will cause everything on the secondary side of the transformer to give out AC voltages as if your line voltage was about 120.28 VAC.
    Added on 5/19/20
    > How to bias your VTA ST-70 or VTA ST-120 amp - see below (ST-70 bias is .400 VDC per each output tube and ST-120 bias is .500 VDC)
    For the VTA ST-120 for the year 2012 to present day ...
    1. Set you multimeter to the 0 to 2 volt DC scale
    2. Place the black probe on the chassis and the red probe in the front LEFT tube socket pin that says "Biaset 1.56 V". Adjust the bias pot on the driver board next to the front left tube so that the meter reads .500 volts DC (that is POINT 5 volts DC or 1/2 volt DC). Next place the red probe in the front tube socket pin that is OPPOSITE the pin that you just used. Use the rear bias pot on the left channel to adjust the rear left output tube to .500 volts DC. If you have a VTA ST-70, then the bias will be .400 volts DC instead of .500 volts DC.
    3. Do the same as #2 above for the right channel
    Facts about bias below ..
    Since all tubes share the bias current > as you adjust one tube UP, the other tubes will go DOWN very slightly. Go back and forth between the four output tubes until all are between .490 and .510. That is plenty close enough. You will never all four output tubes to stay at .500 exactly.
    As the amp warms up from a cold start, the bias will rise very slightly over the first half hour. After 1/2 hour recheck the bias and reset the output tubes so that all are between .490 and .510 VDC.
    If all your tubes have a wandering bias UP or DOWN over time, then probably your line voltage is wandering UP and DOWN.
    If just ONE tube just cannot be biased at .500, then that tube is probably bad or going bad OR possibly the 10 ohm 2 watt resistor that goes from pins 1/8 to chassis ground is bad and does not measure 10 ohms anymore.
    If ALL tubes cannot be biased, then probably your rectifier has a problem.
    Check your bias about once a month. As the output tubes wear in, the bias will change slightly. Check out the "setting the bias on a VTA ST-120" video at the link below. Setting the bias on a VTA ST-70 is the exactly the same except the bias is set lower (.400 VDC per each output tube) on the VTA ST-70.
    Link - Setting the bias on a VTA ST-120
    Added on 6/14/20
    Facts about VTA amp capacitor upgrades
    1. Power capacitor upgrade - On the VTA ST-70/ST-120 are four electrolytic capacitors that supply power to run the board. The upgraded caps are four low ESR (equivalent series resistance) 100 uF @ 400 volt Nichicon caps which are made in Japan. These four caps are physically larger and discharge and recharge at a very slightly faster than the stock power caps. When the amp is played loud these upgraded caps tend to "keep up with the music" a little better. The two bias supply caps are also Nichicon caps. On the VTA ST-120 the SCM (supplementary cap module) are two quality Elna caps which are also made in Japan. The Nichicon and Elna caps are much better than your average Chinese electrolytic caps. Note > There are no Chinese electrolytic caps anywhere on any VTA amp.
    2. Russian PIO main coupling capacitor upgrade - These four capacitors are directly in the signal path. Their job is to take the audio signal from the driver board circuit and pass the audio to each one of the four output tubes. Because they are directly in the signal path, they do have a noticeable influence on the sound of the amp. The most common Russian PIO series used today in audio amps are the K42Y-2, the K75-10 and the K75-24. All three sound very similar .. These caps seem to give a better sense of "space" than standard film capacitors. They give a very large soundstage. On well engineered recordings you can really get an accurate sense of where each instrument is in the soundstage.
    Note > Power supply and Russian PIO caps are optional on the VTA ST-70 and VTA ST-120 but are standard equipment on our VTA M-125 monoblock amps.
    Added on 6/16/20 > Autobias boards ..
    I cannot recommend anymore the autobias boards sold by 3rd party vendors for the VTA ST-70, VTA ST-120 and VTA M-125 amps. These boards are made by Audioamp.eu in the Czech Republic and are now distributed by a USA seller in Arizona. These boards do work properly when installed but the problem has been long term durability of the board itself. I have had now six seven customers who have installed the boards, got them working properly and then had the autobias board fail on them after a few months to about 2 years.
    DCL50C6 and Gustavo Morete like this post
    VTA ST-70, VTA ST-120 and VTA M-125 amplifier information Empty Re: VTA ST-70, VTA ST-120 and VTA M-125 amplifier information
    Post by audiobill Fri May 20, 2016 12:29 pm
    Bob, I've found no audible difference running my ST-120 with KT88s at .50vdc per tube....agree with your recommendations.
    RockyAM
    Post by RockyAM Fri May 20, 2016 1:29 pm
    Bob, in my VTA M-125's I have actually run the bias in both amps at 1.0, 1.10 and 1.20 volts using 4 output tubes. I tried like hell but I honestly could hear no difference in the amps. Of course my wife keeps bitchin' at me "Why don't you just listen to the music instead of fiddling with those things?". I spent another night changing out that front driver tube on both amps and replaying a test track that I use and all I got was "How many times are you going to listen to that damn song!" LOL oh well RockyAM
    jimmeq likes this post
    Post by deepee99 Fri May 20, 2016 3:11 pm
    I have found no audible difference between .5 and .6. Insofar as output tubes are spendy, why not let them loaf a bit?
    WntrMute2
    WntrMute2
    Post by WntrMute2 Sun Jul 03, 2016 8:43 pm
    Will this provide less stress on our poor 5AR4s?
    Post by Bob Latino Sun Jul 03, 2016 8:47 pm
    WntrMute2 wrote:Will this provide less stress on our poor 5AR4s?
    Yes - Besides longer output tube life, the rectifier will also be less stressed ...
    buschfsu
    Post by buschfsu Thu Mar 30, 2017 12:21 pm
    "VTA ST-70 with KT66 or KT77 output tubes > recommended bias setting is .45 VDC per each output tube which gives a bias current of 45 milliamps per each output tube."
    so for my non VTA stock st70 i should read on the front panel port 0.9v (0.45 each for the pair) dc instead of the 1.56v written on the panel?
    Post by stewdan Thu Mar 30, 2017 1:09 pm
    buschfsu -- with stock Dynaco amps, I use 1.25vdc as the bias setting and don't hear anything different from using higher bias voltage settings.  My tubes seem to last longer.
    MechEngVic
    MechEngVic
    Post by MechEngVic Fri May 10, 2019 7:56 pm
    Sorry for the late post,
    It seems the issue is, will a lower than rated bias current affect sound quality. My question is: Will the quality of resistors in the bias reference current circuit or cathode bias resistor affect sound quality?
    Post by Bob Latino Fri May 10, 2019 8:17 pm
    MechEngVic wrote:Sorry for the late post,
    I have listened to the VTA ST-120 and VTA M-125 monoblock amps at 50, 55 and 60 milliamps bias current per each output tube. I have had customers here watch me alter the bias and then we sit and listen to the same tracks over again. There is no discernible audible difference between these three bias settings.
    The cathode bias resistors are 10 ohm 2% metal film resistors that nearly all measure with 1% of each other. I will measure all of these before they go out with a kit to make sure that they are closely matched. Metal film resistors will hold their value over the years much better than the carbon composition resistors found in many vintage amps.
    Post by Roy Mottram Sat May 11, 2019 2:28 pm
    I did the same exact thing 30 years ago when I first created the VTA driver board for the Dynaco ST70 amp.
    That's when I started recommending 40ma per tube for EL34s in the ST70 amp.
    No discernible difference in sound quality, and lots less heat and lots more tube life.
    No measurable difference in output (watts) either. Below 40ma sound quality and power decrease.
    Hops
    Post by Hops Sun Nov 03, 2019 9:34 pm
    Question - How close to 0.5 volts is close enough? On a St-120, how close should the individual Bias values be to each other? Right now I am increasing Bias if it is less than. 0.5 volts, and reducing it if it is over 0.52 volts. Is this reasonable? Should I either tighten up or open up the window?. I use a Variac to target 118 volts, and set it to 118 volts when I check Bias. My VTA-120 probably has 30 hours on it. Even using a variac and a killawat, my voltage probably ranges from 116 to 120 during any given hour.
    Post by Bob Latino Sun Nov 03, 2019 9:57 pm
    Hops wrote:Question -  How close to 0.5 volts  is close enough?   On a St-120,  how close should the individual Bias values be to each other?   Right now I am increasing Bias if it is less than. 0.5 volts,  and reducing it if it is over 0.52 volts.   Is this reasonable?  Should I either tighten up or open up the window?.    I use a Variac to  target 118 volts,  and set it to 118 volts when I check Bias.   My VTA-120  probably has 30 hours on it.   Even using a variac and a killawat, my voltage probably ranges from 116 to 120 during any given hour.
    If your line voltage is all over the place, then don't even try to keep your amp at a "perfect" bias. If all your output tubes are biased between .490 and .510 VDC, that is close enough.
    dakchi
    Post by dakchi Sun May 03, 2020 10:02 am
    Hi Bob,
    It will help new customers a lot to have an assembly video of ST-120. I am interested in buying ST-120 kit, but I find building it based on text instructions very difficult for a newbie. The extra 485$ you charge to build it for us is half of the cost of the amp. I really don't want to buy Chinese amp just because I don't have a video that shows how to build ST-120. I am sure you will sell much more kits if you make this video. A lot of people buy Chinese amps instead of your amps because they have worries that they would not be able to assemble them
    Post by Bob Latino Sun May 03, 2020 10:24 am
    We do have a video of the VTA ST-70 amp kit being built. The assembly of the VTA ST-120 is about 95% the same as the VTA ST-70. The video does not show all steps but does give an idea on how the amp goes together. You get a pictorial and a full color photograph which makes it easy to check what you did on each step. The color photograph and the video for the VTA ST-70 is seen in the first post above on this thread.
    Chinese amps > Many of them look good but some use cheap parts inside where you can't see ... Also ... when you need service on one, where do you go ? Send it back to China ? Need just a replacement part. Are you sure you can get another power or output transformer ? Below is a link to a fairly expensive Sophia tube amp made in China. This gives you an idea of what you can expect from some Chinese amps.
    What a Chinese Sophia tube amp looks like inside
    dakchi
    Post by dakchi Sun May 03, 2020 1:13 pm
    Hi Bob,
    I agree with you that Chinese amps usually use bad quality parts and I do want to avoid buying one, but if I don't build correctly the ST-120, I might lose all the money I put in the amp. I think that it is worth to make a new video for ST-120 when you have the opportunity to build one. The video that you shared is for an old version of ST-70, does not have all the steps and does not include the optional parts. I am sure there are a lot of newbies who will not buy kits just because they do not have such video. This is the only reason why I am hesitating to buy the ST-120 kit. The photo is great but not enough to give me confidence
    I hope you understand
    Thank you Bob
    pedrocols
    pedrocols
    Post by pedrocols Thu May 07, 2020 10:07 pm
    dakchi wrote:Hi Bob,
    Thank you Bob
    Build the amps little by little and you will be very glad you did! There is plenty of support here.
    pavlikkkk
    pavlikkkk
    Post by pavlikkkk Sat Jul 03, 2021 1:31 pm
    [/b]
    [/quote]
    Yes, as you write correctly, these AB-Q-ST70-ST120 boards work properly when connected. We have already sold more than three hundred of them.
    With the recommended connection of fuses with varistors and respecting only one, maximum two cathode current settings, there are no problems with the boards.
    Most often, however, the user often spins with the trimmer on the board. The trimmer is not a potentiometer. Repeated adjustment destroys the resistance layer in the trimmer. The reference setting then loses stability and the cathode current then fluctuates. The trimmer must then be replaced by a fixed resistor.
    If the board is equipped with protection by fuses and varistors, there is no risk of damage to the board even after a tube accident.
    In total, we have sold in the last eight yearsabout a thousand plates of autobias in various designs.
    We use only branded components for their production.
    After experience with their reliability, we provide an UNLIMITED WARRANTY for our modules. We perform repairs free of charge even if you do the customer damages the module himself.
    These terms and conditions are also respected by our representative reseller in America.
    These are our experiences.
    [/size]
    ranges, aguaazul, corndog71, Dave_in_Va, mijohn and New2Tubez like this post
    StevieRay
    Post by StevieRay Sat Jul 10, 2021 3:38 pm
    When was the dual primary taps added to the VTA-120 transformer, for high voltage areas? How do I know if I have this as an option?
    Post by Bob Latino Sat Jul 10, 2021 6:06 pm
    StevieRay wrote:When was the dual primary taps added to the VTA-120 transformer, for high voltage areas?  How do I know if I have this as an option?
    Dual primary wires were added to the VTA ST-120 and M-125 monoblocks in early 2020.
    If you have two BLACK wires, you have the earlier standard VTA ST-120 or VTA M-125 power transformer.
    If you have a BLACK, BLACK/WHITE and BLACK/YELLOW wires, you have the newer dual primary power transformers.
    If your line voltage is below 121 VAC use the BLACK and the BLACK/WHITE wires. If your line voltage is 121 VAC or above use the BLACK and BLACK/YELLOW wires as your power transformer's primary wires.
      Current date/time is Fri Apr 19, 2024 1:46 am
