    new 2016 products
    new 2016 products
    Post by tubes4hifi on Sat May 21, 2016 5:36 pm
    more coming in the future ( always have to be designing some new!! Very Happy  )
    check out our home webpage at www.tubes4hifi.com
    and check out the new Dynaco PAS-4 clone (yes, it's finally a reality!) new PAS-4 clone
    and check out the new 2 way all tube crossover make for die-hard tube fanatics that want the ultimate for bi-amping. all tube crossover
    OK, PASSIVE "preamp" added ! seeit here . . . PASSIVE "preamp" at www.tubes4hifi.com/PP.htm
    Last edited by tubes4hifi on Fri May 27, 2016 5:53 pm; edited 1 time in total (Reason for editing : update)
    Re: new 2016 products
    Post by audiobill on Sat May 21, 2016 6:01 pm
    Thanks, Roy, very impressive list!!!!
    Please consider adding a tube buffer to the list!!!
    bluemeanies
    Post by bluemeanies on Sat May 21, 2016 7:20 pm
    audiobill wrote:Thanks, Roy, very impressive list!!!!
    I second the tube buffer!
    Gregg R.
    Post by Gregg R. on Sun May 22, 2016 1:06 am
    I third the tube buffer!!
    Maybe also, with a high quality attenuator and a switch to toggle between two inputs!
    Post by audiobill on Sun May 22, 2016 5:19 am
    Gregg - that's called a preamp LOL - just keep it simple, one set of inputs/outputs, unity gain and a power switch!!
    wgallupe
    Post by wgallupe on Sun May 22, 2016 6:18 am
    audiobill wrote:Gregg - ...just keep it simple, one set of inputs/outputs, unity gain and a power switch!!
    +1
    Post by tubes4hifi on Sun May 22, 2016 11:44 am
    I can whip up a tube buffer in a day or two . . .
    need a toggle switch or attenuator? Got 'em . . .
    aguaazul
    Post by aguaazul on Mon May 23, 2016 12:45 am
    Good looking tube crossover.
    I Bi-Amp my Bozak speakers with the factory style crossover, they cross at 400Hz. I'm so interested in this.
    On the web page is states:
    Our new circuit board takes the original schematic and makes an EXACT CLONE of the entire circuit.
    I'm looking to see the original schematic. Never heard of it before.
    It would be nice to compare what I have with this.
    On the XO page it states:
    Output is set to 300Hz as a standard, but can be easily changed with ten resistors on four DIP sockets.
    I'd like more info, either here or via PM or Email.
    Thanks.
    Gregg R.
    Post by Gregg R. on Mon May 23, 2016 1:18 am
    I want my tube buffer with an attenuator and a switch to toggle between two inputs; I don't need any gain beyond unity. Then I can sell my Grace M920 since I only use one feature. Call it a tube buffer or a basic preamp, I don't care!
    daveshel
    Post by daveshel on Mon May 23, 2016 1:35 am
    Boy, howdy! It would be nice to see a simple active tube crossover. I've done some reading (I'm not an EE) and there was an interesting article by Pete Millett that described a public domain curcuit, but he wasn't very happy with the end result.
    I've had some great results with bi-amped systems in my years in the car audio biz. My finest system used an Alpine 4-channel amp with active crossovers, and it sounded just like my home systems with acoustic suspension speakers. But I've never been a big fan of seperate woofers/subwoofers in home audio, where there are no space constraints that call for a single woofer.
    I know there are plenty of solid state crossover devices out there, but a paucity oftube devices. My vision would be to be able to use my ST-35 for the tweeters and my MK-IIIs for the woofers, crossed over higher than a subwoofer, maybe around 1Khz.
    wgallupe
    Post by wgallupe on Mon May 23, 2016 7:46 am
    tubes4hifi wrote:I can whip up a tube buffer in a day or two . . .
    Come to think of it, I could use two outputs with a toggle switch. This would allow switching between an ADC/recorder for ripping vinyl and a headphone amp for late night listening....
    buchela
    Post by buchela on Mon May 23, 2016 4:27 pm
    I'm in for the tube crossover
    wgallupe
    Post by wgallupe on Sun May 29, 2016 11:47 am
    Would like to see a tube buffer kit in that same black box enclosure. Maybe design it around a popular tube like a 12AU7/12BH7 or 6DJ8/6922 since those are already used in some of your other kits.
    Consider me signed up for the first one!
    Post by tubes4hifi on Sun May 29, 2016 1:35 pm
    I'm not sure I can fit a TUBE buffer into that same small box, it's only 6x6", but definitely into a larger 8x8 or 8x12" box.
    I have all the parts here, so email me and we'll figure it out.
    Ernstmach
    Post by Ernstmach on Wed Jun 01, 2016 7:58 pm
    Roy,
    look for an email I sent you 3/25/2016.
    wgallupe
    Post by wgallupe on Thu Jun 02, 2016 8:22 am
    tubes4hifi wrote:I'm not sure I can fit a TUBE buffer into that same small box, it's only 6x6", but definitely into a larger 8x8 or 8x12" box.
    Hi Roy,
    Was thinking on the lines of one of these with two outputs and a toggle switch:
    http://www.ebay.com/itm/290827407364?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    http://www.ebay.com/itm/YAQIN-SD-CD3-Stereo-Audio-Processor-Tube-Buffer-/142006431716?hash=item21103e2fe4:g:KRAAAOSwpDdVc2uO
    Regards,
    Wayne
    Post by Sponsored content Today at 4:42 pm
      Current date/time is Mon Sep 26, 2016 4:42 pm
