    gz34 vs 5y3 vs 5u4
    rfbro
    gz34 vs 5y3 vs 5u4
    Post by rfbro on Sat May 21, 2016 10:09 pm
    Wondering if it is ok to use a 5y3 or 5u4 in place of a 5ar4 in my ST 120
    Tubes4ever
    Re: gz34 vs 5y3 vs 5u4
    Post by Tubes4ever on Sun May 22, 2016 1:15 am
    rfbro wrote:Wondering if it is ok to use a 5y3 or 5u4 in place of a 5ar4 in my ST 120
    You can't use a 5y3 since it is rated at 125mA max. You can use a 5u4GB as it is rated at 275mA. The recommended bias setting for the ST120 tubes is 50 mA each for a total of 200mA plus about 25mA for the VTA board. The 5U4 will work just fine.
    Post by Bob Latino on Sun May 22, 2016 7:55 am
    This chart has been posted before .. You can probably use any of the rectifiers that are 250 milliamp (or higher) rated (MaxPma). All the VTA amps have 4 amp rated 5 volt rectifier filament lines (Famp) so any rectifier rated below 4 amps current draw will work as long as the MaxPma is 250 milliamps or higher.
    Tubes4ever
    Post by Tubes4ever on Sun May 22, 2016 11:00 am
    Bob,
    This should be a sticky. Except change "5 volts bias lines" to 5 volt heater windings.
    Tim
    Post by Bob Latino on Sun May 22, 2016 11:14 am
    Tubes4ever wrote:Bob,
    Tim
    Hi Tim,
    Thanks for pointing out ... I made an appropriate change in the text of that post .. Don't know why I said "bias" line. The bias line is 55 VAC .. That would sure make that rectifier light up pretty bright but > for a very short time - lol ..
    Post by tubes4hifi on Sun May 22, 2016 12:17 pm
    Bob & all,
    here's an edited version of the list, only tubes with 250ma or better, and only 8 pin tubes . . .
      Current date/time is Sat Jun 23, 2018 3:48 am
