    Bias run amok
    Bias run amok
    Post by deepee99 on Sat Jun 04, 2016 9:31 am
    Just did the monthly bias check and one of my M-125 Big Boppers has a bias issue. Each of the four tubes can't be dialed down below 1.0 v. It checked out fine last time around but this is a bit scary.
    Since this is a problem common to all four tubes/holes in that amp, any suggestions?
    Re: Bias run amok
    Post by audiobill on Sat Jun 04, 2016 10:05 am
    Have you checked your B+ voltage?
    Re: Bias run amok
    Post by deepee99 on Sat Jun 04, 2016 10:16 am
    Hi, Bill,
    No I haven't. Can't remember how/where to do that.
    Re: Bias run amok
    Post by audiobill on Sat Jun 04, 2016 10:19 am
    On top of the board, you can see B+.....not the same as at the quad cap, but you can compare your amps easily.....
    Re: Bias run amok
    Post by Dave_in_Va on Sat Jun 04, 2016 11:56 am
    I'm not a tech.
    One time my VTA ST70 started sounding bad and upon checking the bias, I found my readings to be around 75-80mA.
    It was the (NOS Mullard) rectifier gone south. Swapped in a Sylvania all has been well since (40mA).
    Re: Bias run amok
    Post by sKiZo on Sat Jun 04, 2016 12:16 pm
    Yup ... good idea to check some voltages, but a potentially simple fix would be to swap the rectifier for a known good spare.
    Before that, I'd just try cleaning the pins and socket. Also retension the socket so you're sure you've got good contact all around.
    No luck there, next best bet would be a cold solder joint. Easy enough to reflow if you know what you're doing, and a close eyeball inspection as well as all of the above should be the first steps any tech should try if you do take it in for service.
    Re: Bias run amok
    Post by arledgsc on Sat Jun 04, 2016 2:41 pm
    Check the bias negative voltage power supply as well. You will run out of adjustment range if it starts going positive of nominal.
    Verify the power supply electrolytic caps look healthy (no outwardly domed end-caps or dried electrolyte clues). A leaky cap can load the supply and throw voltages out of whack.
    Re: Bias run amok
      Current date/time is Mon Apr 23, 2018 7:57 am
