    Weird measurements
    Weird measurements
    Post by corndog71 on Fri Jun 10, 2016 9:48 pm
    So I finally got a Kill-a-watt and it's pretty cool.  My main rig is drawing around 2.6 amps at idle.
    One thing that surprised me was that with my fluke 77 meter I would typically measure 125vac from the wall.  Tonight the KAW shows 118vac.  I double checked it from my meter and it shows 120vac (L-N).
    My ST120 is on a variac and I wanted to confirm the output of it so I initially checked from L-Ground and got 146vac!  I kinda freaked and turned it down to 117vac.  Then I checked from L-N and only measured 47vac.  Then I looked at the amp and noticed the filaments were barely glowing so I turned it back up to 117vac (L-N).  I went back to measure L- ground and now show 155vac!  Fascinating.
    I also plugged one of those polarity checkers into the wall and my assortment of filtered power strips and they all checked out correctly wired however when I plugged it into the variac I just get the red led lit.  scratch  I guess this is just how a variac works.
    Re: Weird measurements
    Post by Kentley on Sat Jun 11, 2016 12:58 am
    Sounds like your variac is very-ac. As in cooked.
    The Fluke is likely the steadiest measure, providing its batteries are full, and leads clean.
    If your incoming AC is above 118 VAC you might try a rectifier switch. See other threads for advice.
    When you have multiple devices "regulating" your power, and they disagree, best to simplify. Maybe it's just the wind...
    10-E-C
    Post by 10-E-C on Sat Jun 11, 2016 6:14 am
    You may get different readings from G - L and N - L if the ground is isolated from neutral in your equipment. I saw this all the time in old equipment (47vac) where where the neutral isn't bonded to ground.
      Current date/time is Sun Jan 21, 2018 10:38 am
