    Dynaco MK3 Original Circuit board Component layout.
    bubbasweet
    bubbasweet
    Dynaco MK3 Original Circuit board Component layout. Empty Dynaco MK3 Original Circuit board Component layout.
    Post by bubbasweet on Fri Jul 15, 2016 11:57 am
    Can someone point me in the right direction for this? The service manual does not have the component layout of the original circuit Board or Component layout for it with values.. THX
    Dynaco MK3 Original Circuit board Component layout. Empty Re: Dynaco MK3 Original Circuit board Component layout.
    Post by tubes4hifi on Sun Jul 17, 2016 4:46 pm
    DynaKitParts.com sells a manual for the PCB . . . . http://www.dynakitparts.com/dynakit-products/PC%20Boards/DYNAKIT-PC-BOARD-MANUALS
    the MK3 amp used a PC-1
    also a google search will take you to this page with a PCB diagram
    http://audiokarma.org/forums/index.php?threads/dynaco-mark-3-rebuild-questions-and-problems.565396/
    PeterCapo
    PeterCapo
    Post by PeterCapo on Sun Jul 17, 2016 5:40 pm
    At least one correction to that diagram on AK...  The 0.1uF cap next to the tube has a 400VDC rating - 600 VDC here is not necessary and might result in a larger part getting roasted by the tube because it will sit closer to it, especially if it has radial leads.
    bubbasweet
    bubbasweet
    Post by bubbasweet on Mon Jul 18, 2016 12:43 pm
    THX Tubes hifi and Peter. Much Appreciated.
      Current date/time is Wed Oct 16, 2019 9:51 pm
