    Turret? Or is there a better way?
    Turret? Or is there a better way? Empty Turret? Or is there a better way?
    Post by j beede on Sun Jul 17, 2016 10:20 pm
    I want to add some sort of grounded post to a PCB so I can do some grounding experiments. I suppose I could drill a hole in the board and use a 4-40x1/2"  or 2-56x1/2" screw and nut to create a post to solder to. I don't have room to add lugs to solder to. I've never used turrets... is this a better way to go?
    Most all the work I do is point-to-point so I am (much) less familiar with PCB-oriented tweaks and what is available.
    kaner
    kaner
    Turret? Or is there a better way? Empty Re: Turret? Or is there a better way?
    Post by kaner on Sun Jul 24, 2016 9:31 pm
    Turrets are pretty easy to use, and easy to solder to. All of the guitar amps that I've built use turret boards. I make my own turret bards from blanks so the layout is custom fit for what i need. You will need some turrets, turret board material, a drill and a punch. You can also use eyelets. Same principle but different style. You can also find blank turret boards if it fits your need.
      Current date/time is Wed Aug 21, 2019 2:11 am
