I want to add some sort of grounded post to a PCB so I can do some grounding experiments. I suppose I could drill a hole in the board and use a 4-40x1/2" or 2-56x1/2" screw and nut to create a post to solder to. I don't have room to add lugs to solder to. I've never used turrets... is this a better way to go?
Most all the work I do is point-to-point so I am (much) less familiar with PCB-oriented tweaks and what is available.
