    Identify the Driver Board on a Modded ST-70
    Mandopicker
    Mandopicker
    Identify the Driver Board on a Modded ST-70 Empty Identify the Driver Board on a Modded ST-70
    Post by Mandopicker on Mon Aug 15, 2016 7:48 pm
    I've already sent images of the board to Bob, but thought you all might like to see the inside of one of my ST-70.  I acquired it along with four others and a Pilot - this one was modded by a real great guy and a tube amp genius/mentor and friend.  Bob hasn't confirmed this, but he believes, from my description, that the board is an earlier version from the 1990's.
    It did not have the tubes so I wanted to be sure which version it could be.  The 12AU7 version, or the 12AT7 version.  I had a suspicion from the part values...but good to know for sure.
    Thanks for looking into it Bob. Enjoy.
    Identify the Driver Board on a Modded ST-70 Vta-st13
    Identify the Driver Board on a Modded ST-70 Vta-st12
    Identify the Driver Board on a Modded ST-70 Vta-st11
    Identify the Driver Board on a Modded ST-70 Vta-st10
    Identify the Driver Board on a Modded ST-70 Empty Re: Identify the Driver Board on a Modded ST-70
    Post by Bob Latino on Mon Aug 15, 2016 8:01 pm
    I Emailed Roy Mottram who designed this board. His reply was that the board on your amp is "an early version of the VTA driver board that dates back 20 - 25 years." I believe the board did use 12AT7 driver tubes.
    Mandopicker
    Mandopicker
    Post by Mandopicker on Tue Aug 16, 2016 2:46 am
    That's amazing Bob. Thanks a bunch. There is a lot going on inside this thing, and I will enjoy/go mad working it all out. Any chance of a schematic being available? Lots of things I haven't seen...not saying a whole lot...and certainly unique to my original ST-70's.
    Again, many thanks to yourself and Mr. Mottram for sharing your valuable time.
    Best, David
    Post by tubes4hifi on Tue Aug 16, 2016 12:10 pm
    yes, that's a board from 1989 or early 90s, using 12AT7 tubes, my original design
    Mandopicker
    Mandopicker
    Post by Mandopicker on Tue Aug 16, 2016 12:33 pm
    Honored that you took the time to confirm it and doubly cool to meet the designer.  Kudos to this fantastic site!
    Ever since I cobbled up a my first guitar amp as a kid, I have been fascinated with all of this stuff. Especially tubes of all kinds. Since, have built many guitar amplifiers, etc.
    Only recently, due to the fantastic gifts from a dear friend and mentor, have I started to dive deep into hifi designs.  I love the cross training!
    If I might ask while I have this unique opportunity, is it pretty much the same circuit or have there been improvements to it as the years have gone on?  It sounds great and I will enjoy its uniqueness.
    Again, your time and attention is greatly appreciated.
    Best,
    David
    Post by tubes4hifi on Tue Aug 16, 2016 1:23 pm
    welcome David,
    the circuit you have is schematically identical to what was offered up until about 3-4 years ago (no improvements really necessary!!)
    The only real change the past couple years was to change a few components to use lower gain 12AU7 tubes and to add a CCS circuit for each phase splitter.
    From what I could see in the photos, there is a pretty good chance that I actually stuffed the parts on your board,
    and punched the holes in the chassis for the 3 large capacitors.
    Roy Mottram - Vacuum Tube Audio - tubes4hifi
    Mandopicker
    Mandopicker
    Post by Mandopicker on Tue Aug 16, 2016 4:02 pm
    Even more cool to know you might have stuffed it. Not sure how my friend acquired all of these Dynaco units I now have, but I do know he would appreciate; and likely knows full well, your expertise. I do appreciate this very much.
    Now I got to dig into several PAS preamps (3,4's), FM-3's etc. to put together a kick-butt system.
    Have a fantastic day.
    Sincere regards,
    David
    Mandopicker
    Mandopicker
    Post by Mandopicker on Sat Nov 19, 2016 3:26 am
    Hi Roy,
    Been meaning to ask...if there is any documentation available from the time this board was new. Build instructions, bias tips, etc. I'd love to have it to go with the unit. Totally enjoying it. Thank you again for sharing your knowledge.
    Post by Tube Nube on Sat Nov 19, 2016 2:00 pm
    Welcome to the board Mando. Plan to get stuck in here--it's a friendly corner of the web to learn, get help, and to enjoy the company of other Dynaco loving, fiscally restrained audio philiacs.
    Post by tubes4hifi on Sat Nov 19, 2016 7:02 pm
    the oldest documentation I have is around 5 years old, but the circuit should be nearly identical to what you have.
    send me an email at info@tubes4hifi.com and I will send you an old PDF file
    Post by Tube Nube on Sat Nov 19, 2016 7:25 pm
    See, this is the kinda customer service you get around here--you're not even a customer yet, and you get service direct from the man himself!
    Mandopicker
    Mandopicker
    Post by Mandopicker on Mon Nov 21, 2016 1:01 am
    Couldn't be more happy to be here and look forward to contributing.
    Best...
      Current date/time is Thu Jan 23, 2020 5:43 am
