    SPDIF input for upgraded PAS3X
    TN Allen
    SPDIF input for upgraded PAS3X Empty SPDIF input for upgraded PAS3X
    Post by TN Allen on Sun Sep 11, 2016 10:55 am
    Would anyone know of, or perhaps may be using a tube or SS PCB that might be sqeezed into an upgraded PAS3X or new SP9 to connect a CD player using SPDIF. I can do this with an external DAC that would connect to the PAS3X with analog RCA cables, but I'd like to think I can add this inside the chassis. Thanks
    SPDIF input for upgraded PAS3X Empty Re: SPDIF input for upgraded PAS3X
    Post by tubes4hifi on Mon Sep 12, 2016 9:40 am
    you'll need to convert SFDIF to audio format first
    check ebay, lots of chinese vendors have interesting and inexpensive options to do things like that
    Post by corndog71 on Mon Sep 12, 2016 2:05 pm
    This one is pretty tiny but you would have to wire in a USB power supply.
    http://www.parts-express.com/fiio-d03k-coaxial-optical-dac-digital-analog-converter--230-120
    Of course there are probably much better external dacs out there that might be a bit bigger.  I recommend Musical Fidelity V-90 DAC.  http://www.audioadvisor.com/prodinfo.asp?number=MFV90DAC  It comes with a wall wart power supply.
      Current date/time is Mon Aug 26, 2019 6:30 am
