I think I may have caught the bug I already had a PAT 4 for years then got the PAS 2 recently and now this FM 1 I got the other day. It powers up but the blue eye wasn't blue and there wasn't any sound. Took the shielding off of all the tubes and they were lit except the rectifier but if you look at the tube, it is smoked so I have another on the way and then I will try again. These were taken moments after unboxing prior to cleaning and plugging in. Not sure where that piece of shielding goes that was lying loose unless it was supposed to be part of the shield around the rectifier.
+2
rodneyk915
6 posters
PAS 2 Got a Sister
Peter W.- Posts : 1351
Re: PAS 2 Got a Sister
The rectifier is unshielded on the FM1 & 3. However, other than the EM80 eye tube for a 1, all the others are shielded. Note that the tube bases have a small metal tongue that friction-connects to the shield when it is slipped over the tube down to the base.
The FM1S & the FM3 use the EMM801 dual eye tube. That, as it happens, is very nearly unobtanium these days. Technically, you have an FM1S as it has the stereo board. Count yourself lucky.
That bit of metal looks like scrap.
GP49- Posts : 792
Won't work at all without a functioning rectifier. Don't give up on your EMM801 eye tube yet.
I got the last new one Dynaco had...so said the note accompanying it, from Bob Tucker!
rodneyk915- Posts : 16
Thanks for the info. I was happy to see the eye tube light up, I had read they were pretty much impossible to replace. Should have the rectifier by the weekend then I'll give it another go.
Dave_in_Va- Posts : 443
This must be why I have trouble selling books on eBay these days. Nobody even looks anymore.
There are several EMM801 tubes on listed there now. Not that expensive.
Pretty complicated looking guts in that tube!
GP49- Posts : 792
- Post n°6
rodneyk915 wrote:Thanks for the info. I was happy to see the eye tube light up, I had read they were pretty much impossible to replace. Should have the rectifier by the weekend then I'll give it another go.
There are no more new ones (officially...there are probably some in private hands, or in unbuilt FM-3 kits). Used ones are out there, from scrapped FM-3s.
eickmewg- Posts : 103
- Post n°7
I got a supposedly NOS EMM801 from an eBay seller for $40 awhile back. It came in a pristine, properly labelled Telefunken tube box with perfect lettering on the tube so it sure looked NOS. So, they are out there if you keep your eyes open. The new tube was considerably brighter than the old tube.
- Post n°8
I have two NIB spares that I got from a rather prestigious audio sales/service shop back in the day when the owner retired. A friend and I helped him move out, and also helped him sell off his attic inventory via our friends and acquaintances. This was over 30 years ago, and the stuff in that attic was then considered useless. Today, not so much.
As our 'reward', he allowed us to divide his tube stock for $1 per tube irrespective of type, brand and so forth. There were four EMM801s. NOTE: in the years since and across MANY FM3s, I have never yet had the need to use one. Most are stripped of their 12AX7s, but not of the eyes.
- Post n°9
By the way, you can always go solid-state on the rectifier. The cap would be a 0.10 uF @ 600V.
https://s213.photobucket.com/user/flemingmras/media/Cycle1.jpg.html
There are any number of configurations, but this is one I have used.
peterh- Posts : 1823
- Post n°10
Rodney,
the rectifier is a 6v4 / EZ80. I have in stock, but that won't help you i suppose.
As already mentioned you can replace the ez80 with 2 1n4007 diodes ( or un4007) ,
this could be done temporarily to check out the rest.
- Post n°11
Thanks for the info and suggestions. I got the rectifier a little while ago and put it in and everything is working perfectly now
