    Variacs and GFCIs
    Variacs and GFCIs Empty Variacs and GFCIs
    Post by deepee99 Tue Oct 04, 2016 1:02 pm
    A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
    Variacs and GFCIs Empty Re: Variacs and GFCIs
    Post by corndog71 Tue Oct 04, 2016 3:16 pm
    deepee99 wrote:A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
    Well, think about it this way: Whatever you plug into the GFCI will be protected by the GFCI. If you want to also protect your variac then plug your variac into the GFCI.
    Post by deepee99 Tue Oct 04, 2016 3:27 pm
    Thanks. The reason I asked was I had a variac that developed a ground fault all on its own...
    Post by Peter W. Tue Oct 04, 2016 4:09 pm
    Variacs are Variable Autotransformers - meaning that they are NOT isolation transformers - there is only one (1) winding, with a variable take-off to control voltage. Those who expect them to behave as a standard transformer could be unhappily surprised. And, if tested as a standard dual-or-more-winding transformer, they will display faults right down the line.
    http://www.electronics-tutorials.ws/transformer/trans33.gif?x98918 Variac Schematic.
    Multi-winding multi-tap transformer: http://www.learnabout-electronics.org/ac_theory/images/Power-txfmr-shematic.gif Note that there is no connection between the primary and the secondary.
    NOTE: Unless you have a metered variac - volts and amps - it is, really, not very useful, and in fact can be genuinely dangerous.
      Current date/time is Fri Apr 19, 2024 1:32 pm
