    hum in a SP14
    Marvins
    hum in a SP14
    Post by Marvins on Sat Oct 01, 2016 12:44 pm
    Looking for someone to point me in the right direction . I have purchased Bobs ST120 a few a years back and it went together with out a hitch. I love the amp. I have a pair of home built K-horns and horns love tubes . I was running and old SS preamp with the St120. It was great , but I decided this past summer to mate it with Roy,s SP-14 .
    I took my time and the summer to build it. I had a couple of errors along the way , like the back on the front and attenuators upside down . Lol . Ordered more wire , tore it apart and made it right. But I had a hum I could not find and finally threw in the towel and sent the board back to Roy . I had two sets of resistors mixed up as I had either marked them wrong or measured them wrong with the meter. It was , I think 280 Ohms verses 280 k ohms ? Anyway Roy changed them , tested the board and sent it back.
    But the problem still persists . Rotating the volume attenautor from low to high ........ There is distinct hum at the low end , this lessens or disappears by mid point. At the extreme end of the dial ( or max ) the hum will re-appear. This is with no input running of course . Plays music sounds ok at mid volume. But to me I don't get as much volume as I would like either ?
    I used a SS preamp prior too and it had plenty of room . System is in the basement and I crank it sometimes when we are upstairs.
    I had to unsolder and turn the attenuators around , so not sure if they could be over heated them and cause me problems. That will be my next step. Order a new one and run directly to it from one of the jacks.
    This what I have done so far:
    All voltages check out as per Roy's instructions. I have tried new tubes. I have wired directly from one set of jacks to the attenuators , thus bypassing 90 percent of the wiring and switches with in . I ran a ground from the board to the ground buss to try that and nothing changes.
    We will assume the board is fine as Roy tested it . Either I have missed something or a transformer? Not sure how you could check that as I don't have an oscilloscope .
    And yes I probably should have just sent the whole thing back , but I was sure it was the board and cheaper to send it as I live in Canada.
    I see Roy is away. So any help would be much appreciated.
    Re: hum in a SP14
    Post by deepee99 on Sat Oct 01, 2016 2:00 pm
    I'm wondering if the coupling caps in your SP-14 are able to match the lower input impedance of the s/s power amp. You might find some beefier ones.
    If you've done a tube swap, might also look to external wiring as well. Coax too close to AC lines (unless they're crossing at 90 degrees) can induce a lot of hum.
    Re: hum in a SP14
    Post by j beede on Sun Oct 02, 2016 8:12 pm
    Hello Marvins,
    Sounds like a ground loop. Does either your amplifier or preamp have a three prong power plug?
    ...j
    Re: hum in a SP14
    Post by deepee99 on Sun Oct 02, 2016 8:36 pm
    j beede wrote:Hello Marvins,
    ...j
    Agree with beede, and ground loops can be extremely loud. Try using a cheater plug to lift the ground(s) and see if that does the trick.
    Marvins
    Re: hum in a SP14
    Post by Marvins on Sun Oct 02, 2016 9:02 pm
    The pre SP14 has a 3 prong plug and the ST120 has a 2 pronged plugged. No cheater plugs in Canada , but I can just remove the ground inside the Sp14 to try that. I would have thought it would have been designed to handle that . I did separate the two to deferent plugins but that did not work .
    Thanks for the response
    Re: hum in a SP14
    Post by deepee99 on Mon Oct 03, 2016 12:45 pm
    Marvins wrote:The pre SP14 has a 3 prong plug and the ST120 has a 2 pronged plugged. No cheater plugs in Canada , but I can just remove the ground inside the Sp14 to try that. I would have thought it would have been designed to handle that . I did separate the two to deferent plugins but that did not work .
    Marvins, if you'll PM me, I have a drawer full of cheater plugs) and would be pleased to mail you a couple of them. They're like $1 apiece. But forget that. Every old house needs a few of them. Having lived on both sides of the border most of my life, I'm quite adept at the art of smuggling. When in Vancouver I always pick up a big jug of AC&Cs, which you need a scrip for down here, and take Melatonin northwards which you can buy OTC here but not up there. Go figger.
    Zimmer64
    Re: hum in a SP14
    Post by Zimmer64 on Mon Oct 03, 2016 2:26 pm
    I think you can try running a cable from chassis to chassis (or from RCA to RCA) and see if your hum goes away. Cured it once for me.
    Kind regards
    Michael
    jkaukas
    Re: hum in a SP14
    Post by jkaukas on Tue Oct 04, 2016 6:49 am
    Not sure this will help your issue or not, but I was able to resolve a hum issue on my SP14 by doing the following. This was after ruling other issues such as wiring and soldering mistakes, voltage issues and inductances from wiring proximity. I followed the standard wiring instructions exactly but for the inputs but made the following changes. I removed the ground bridge jumper wire on the volume control between channels (as indicated in the instructions) and I also wired both of the grounds from the volume control to the input grounds on the pcb. On the output side, I still kept the single ground wire from the output to the PCB as per instructions. This change worked with the basic potentiometers that came with the kit, and possibly my issue was related to a ground loop created with the channel bridge from the volume control.
    wanders
    Re: hum in a SP14
    Post by wanders on Fri Nov 11, 2016 11:38 am
    Had two hum/noise issues in building my sp-14: grounding and wiring. If you built the kit, then grounding should be straightforward, just follow the directions. I did not build the kit and had to try numerous iterations before getting it right. As to wiring, I originally wired with 24 awg, silver plated, twisted pair, silver shielded, teflon jacketed wire. (essentially the Don Sachs wiring). Not only was the wire cumbersome to work with, I ended up with hum that was noticeable at about half volume with no play back - not noticeable with music playing. I pulled all of that wire out and replaced it with Mogami 2330 mini-coax. The preamp is now absolutely, 100% dead quiet, to the ear and on the scope, at any volume level. You can get that wire at Markertek for $0.25/foot with free shipping. It's pretty delicate to work, however.
    Re: hum in a SP14
    Post by deepee99 on Fri Nov 11, 2016 12:04 pm
    Hum is an invented word because all of the genuine cuss-words, including "golf" were already taken. Curing it is largely a process of elimination. If you've got one noisy channel, the problem is likely a tube on that side, or the wiring between the pre-amp and power amp on that side. If there's hum on both sides you can pretty well rule out a lame tube and the odds that two (one on each channel) have gone south are exponential.
    I deal with this mess every time I swap out a component and nine times out of 10 it's the cabling. Keep the AC wiring as far as possible away from the low-level stuff (carried by the RCA cables). Or you could have an external ground loop involving the AC, whereupon at your own peril you lift the ground from one of the components.
    Or, you could take up golf and learn all their words for hum.
    Marvins
    fixed
    Post by Marvins on Sat Dec 17, 2016 8:56 pm
    Problem fixed , I had to stare at it for awhile . I was missing one ground from left side gain control to center attenuator. Hummmmmm free.
    Don't think its loud enough though ?? I will ponder that one.
    Marvins
    low volume
    Post by Marvins on Sat Dec 17, 2016 9:06 pm
    I have a ST120 that's about 4 years old and a just built the SP12. I seem to have a lot lower volume with it verses the SS preamp I was using.
    Not sure why as everything is quiet and it runs fine and all voltages check out. Tried another set of tubes and no change I still max out the gains.
    But with the tubes 4 years old on the amp could it be time to change them out ? I was going to get another set anyway and I was just wondering.
    They have had a lot a play over the years. The rectifier tube pops from time to time and I just keep a spare. Would this be a normal life for the
    KT88 ?
    You thoughts and thanks.
    Re: hum in a SP14
    Post by tubes4hifi on Tue Dec 20, 2016 12:38 pm
    I was just going to say it sounds from your descriptions that maybe the volume control(s) aren't grounded, but seems you maybe fixed that (or PART of that problem).
    If you are using the two gain controls also, those also need to be grounded. I will email the correct hookup again (as was in the SP14 build manual)
    and also photos of the wiring.
    Re: hum in a SP14
      Current date/time is Thu Jul 19, 2018 9:19 pm
