+2
10-E-C
Dahlberg
6 posters
Experience of 5963 tube
10-E-C- Posts : 267
Re: Experience of 5963 tube
Dahlberg wrote:This was an interessting articel.
http://www.jacmusic.com/nos/ECC82/5963/5963-index.htm
I run 5963s in my M125s and also in my ST-70. I found some Phillips 5963s that sound wonderful in my M125's and A JAN 5963 in my center position of my ST70. I don't think you can go wrong with the 5963s.
TM
Jim McShane- Posts : 237
I would caution however that the 5963 often tends to be microphonic. While they are used in less sensitive positions in Bob & Roy's gear they can still cause you grief.
Be sure the tubes you get are tested for microphonics!
Dahlberg- Posts : 132
I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
Rabindu- Posts : 6
I'm using an RCA USN CRC 5963 with black plates and a foil "D" getter of 1958 vintage in the centre voltage amplifier position in my ST-120 with excellent results.
Also have in the left and right phase splitter/inverter positions a matched pair of RCA JRC-5814A with 3 micas, black plates and a square getter of 1959 vintage. Got these NOS tubes from a reliable seller on ebay.
Mike Kampman
Mike Kampman
peterh- Posts : 1833
- Post n°6
Dahlberg wrote:I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
That was expensive ! I hope the sound is accordingly.
- Post n°7
peterh wrote:Dahlberg wrote:I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
Do you have a better price ?
eickmewg- Posts : 103
- Post n°8
I got some GE 5963's awhile ago. I found them to be rather noisy and I went back to 12BH7's for my ST120.
- Post n°9
On ECC82/802 /12au7 ? Yes. 120 swedish crowns, including sales tax.Dahlberg wrote:peterh wrote:Dahlberg wrote:I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
- Post n°10
Nothing wrong with those prices but this was for the 5963 and the conclusion of the
articel. I'm guessing you have a different opinion about the virtues of this tube ?
I'll give you a call for some more tubes.
Edit: Couldn't find a phone nr on your homepage ? PM maybe ?
- Post n°11
Dahlberg wrote:Nothing wrong with those prices but this was for the 5963 and the conclusion of the
I had 5963 in my vta-70 as delivered. But one of them developed hum after
some 1000 hours so i replaced them ( no use replacing only one), the remains
was given to a curious customer for free.
What did i use ? JJ-ECC82. It still sounds good.
http://tubular-well.se
- Post n°12
I agree that the JJ ECC82 is a very good tube; cheap and quiet. Unfortunately, I had a trio of these tubes in a plastic bag and my dog managed to pull it off the counter. By the time I got them back, he had done a number of the pins on one of them! I now have a duo
- Post n°13
I hope the dog did not swallow any of the pins, they might puncture the internals.eickmewg wrote:I agree that the JJ ECC82 is a very good tube; cheap and quiet. Unfortunately, I had a trio of these tubes in a plastic bag and my dog managed to pull it off the counter. By the time I got them back, he had done a number of the pins on one of them! I now have a duo :x
At least you have 2 left, you can listen to stereo with them !
