A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
Variacs and GFCIs
corndog71- Posts : 840
Re: Variacs and GFCIs
deepee99 wrote:A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
Well, think about it this way: Whatever you plug into the GFCI will be protected by the GFCI. If you want to also protect your variac then plug your variac into the GFCI.
deepee99- Posts : 2244
Thanks. The reason I asked was I had a variac that developed a ground fault all on its own...corndog71 wrote:deepee99 wrote:A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
Peter W.- Posts : 1351
deepee99 wrote:Thanks. The reason I asked was I had a variac that developed a ground fault all on its own...corndog71 wrote:deepee99 wrote:A lot of people on this forum swear by Variacs. A simple and likely dumb question. Would the Variac plug into the GFCI, or would you put the GFCI(s) on the output side?
Variacs are Variable Autotransformers - meaning that they are NOT isolation transformers - there is only one (1) winding, with a variable take-off to control voltage. Those who expect them to behave as a standard transformer could be unhappily surprised. And, if tested as a standard dual-or-more-winding transformer, they will display faults right down the line.
http://www.electronics-tutorials.ws/transformer/trans33.gif?x98918 Variac Schematic.
Multi-winding multi-tap transformer: http://www.learnabout-electronics.org/ac_theory/images/Power-txfmr-shematic.gif Note that there is no connection between the primary and the secondary.
NOTE: Unless you have a metered variac - volts and amps - it is, really, not very useful, and in fact can be genuinely dangerous.
