+8
pedrocols
vtshopdog
LeGrace
Dahlberg
aguaazul
12 posters
My KT120 / M-125's
Dahlberg- Posts : 132
- Post n°26
Re: My KT120 / M-125's
It's coming along
LeGrace- Posts : 388
- Post n°27
Love your carpentry skills!
- Post n°28
Thanks, some decent tools helps a lot I decided on a very simple profile and
just added a 45° angle over the corners to make them a bit more durable.
- Post n°29
Dahlberg wrote:Thanks, some decent tools helps a lot I decided on a very simple profile and
My attempt at doing mitered corners was a total fail. Yours look amazing!
- Post n°30
Well without the tools it just doesn't work. Hard enough with them.
- Post n°31
This is my dsp xo, no mitred corners and usually turns out good looking.
Kentley- Posts : 496
- Post n°32
That is simply stunning, sir. The wood knob is superb. All my hats are off. I'm running out of hats.
- Post n°33
Thanks. To bad I have to build a new one The first one has two hardwired "Unballancers" but
I'm rebuilding for tubes on all outputs using the pcb's from John Broskie.
Then there is just not enough space. The sub output is opamp based today and I also had
the possibility to run a second identical opamp buffer for mid bass for a while, but the
"Unballancer" came out such a strong solution that I decided to use that for the sub region as well.
It's all based around the "Najda" dsp and three separate "BuffaloIII" dacs.
Twisted pear is releasing the "BuffaloIV" using the new "Ess 9038pro" chip in the hopefully not
so distant future and I'm waiting for the 8-channel version of that dac, the project is on
a stand still for now. The surprisingly strong result from the output buffer shootout was one of
the reasons that I decided to try a tube power amp solution in that region as well.
It's not possible for the sub section though.
Edit: Picture
Edit: Picture
aguaazul- Posts : 136
- Post n°34
Looking good all around! I'd be interested in looking at the full build history on your DAC solutions if you don't mind sharing.
Cheers,
Blue
Cheers,
Blue
- Post n°35
aguaazul wrote:Looking good all around! I'd be interested in looking at the full build history on your DAC solutions if you don't mind sharing.
Cheers,
Blue
If you do a Google picture search for "najda dahlberg dsp" you will find most of the
information (at diyaudio). The "Najda thread" is a bit hard to read through (300+ pages)
but with the pictures to go from you would start at the more relevant pages.
For information about the new solution a good place to start would be the unbalancer manual.
http://glass-ware.com/User_Guides/Unbalancer%209-pin%20-PS.pdf
The "BuffaloIV" doesn't exist yet but the "buffaloIIIse" is what I have been using up till now.
http://twistedpearaudio.com/digital/buffalose.aspx
And since this is a picture thread about the M-125
- Post n°36
Mad wiring skills
- Post n°37
Don't know about that, but hopefully it will work when it's done.
Roy Mottram- Admin
- Post n°38
I tend to keep my oven around 200-225 to cure paint, not any higher, and usually 15-20 minutes is plenty
- Post n°39
Well the next time I will use spraypaint I will be more careful with temperature. Bad news about the powder coating as well.
The "candy gold" didn't turn out good at all and the paintguy thought it was a problem with the powder itself.
So now there is a new colour in the making. Candy red this time, a quite dark one.
- Post n°41
I could not help myself so I had to see how it looked with tubes in place. It turns out a bit lighter on camera then it looks.
- Post n°42
Stunning! What did you do with the power switch? Have you considered brass plaques for the front?
- Post n°43
The power switch is on the back, you can see part of it on an earlier picture. I'm not planning for any brass plaque, hmmm.
- Post n°44
Got them fired up yesterday, and got some slight hum. Trying a screened feedback cable today to see if that solves it. Got a tip at diyaudio from a Canadian guy who had the same issue, apart from that it was a rawing review Mine sounds promising
vtshopdog- Posts : 155
- Post n°45
Dahlberg wrote:Got them fired up yesterday, and got some slight hum. Trying a screened feedback cable today to see if that solves it. Got a tip at diyaudio from a Canadian guy who had the same issue, apart from that it was a raving review Mine sounds promising
Do I understand correctly that you are replacing the yellow(usually?) wire that runs from the O.T. to PCB with a splice of shielded cable?
Beautiful build BTW
- Post n°46
vtshopdog wrote:Dahlberg wrote:Got them fired up yesterday, and got some slight hum. Trying a screened feedback cable today to see if that solves it. Got a tip at diyaudio from a Canadian guy who had the same issue, apart from that it was a raving review Mine sounds promising
Beautiful build BTW
Yes it's the yellow one. I cut it short just leaving a few centimeters for connetion to a screened
cable that I connected to the pcb. The screen is only connected to ground at the input board.
I'm using twisted wire for the line level input, maybe a screened cable would be an idea there as well
So first initial listening impression
I really like the synergy they create with my 300b amps. Everything just seems to fit better together
resulting in a more relaxed and natural listening experience. I have a gain structure that is based
on the possibility to go to full blast without distroying anything and full blast now feels less loud (less distortion?).
Wood intruments and percusion sounds more natural, the lower notes on saxophone are just fenomenal.
Dynamics are at least as good as earlier or even better, I'm leaning to the second on that.
For now the only thing that could use some attention is the lowest bass region, where they leave over to
the subs. It seems that I have lost some definition in that area. Maybe another rectifier solution and also try the 8 ohm tap ?
I'm only using them from 65-350hz.
- Post n°47
There are some small adjustments left but it's slowly coming in to place
- Post n°48
So now the feedback wire is relocated as described in the picture and I
measured less than 2,0 mV ac of the speaker connections. This amp is very quiet.
Only difference is that in my amps the wire comes closer to the bottom of the cabinet.
Thanks to Bob and some other guy at DIYAUDIO for pointing this out.
pedrocols- Posts : 162
- Post n°49
Very nice! I have mine for a little over two years now and still running strong. I suspect I will have to shortly get some new tubes.
- Post n°50
Thanks, I'm doing some evaluation regarding what output tap to use. Tomorrow.
