    Screw loose!
    mazeeff
    Screw loose! Empty Screw loose!
    Post by mazeeff Sat Oct 29, 2016 11:07 am
    I have been fighting a drifting bias problem on my VTA-70 for a couple of days. The problem was related to a single socket, and was not tube related. The bias on that socket would drift from 35-45ma, and change as the temp increased. I checked all the bias resistors, and bias circuit. Everything was spot on. While making another measurement on the 10 ohm bias resistor, I noticed that the resistance was jumping from 10 to 16 ohms! Closer examination uncovered a loose socket screw, which the bias resistor uses to make its ground connection. Tightened the screw, and all is well. Seems like a good idea to periodically check all screws/nuts related to the ground distribution!
    Mike
    Screw loose! Empty Re: Screw loose!
    Post by peterh Sat Oct 29, 2016 12:20 pm
    mazeeff wrote:I been fighting a drifting bias problem on my VTA-70 for a couple of days. The problem was related to a single socket, and was not tube related. The bias on that socket would drift from 35-45ma, and change as the temp increased. I checked all the bias resistors, and bias circuit. Everything was spot on. While making another measurement on the 10 ohm bias resistor, I noticed that the resistance was jumping from 10 to 16 ohms! Closer examination uncovered a loose socket screw, which the bias resistor uses to make its ground connection. Tightened the screw, and all is well. Seems like a good idea to periodically check all screws/nuts related to the ground distribution!
    Mike
    Screwing in stainless steel is not a perfect way of grounding. Myself used a
    coarse copper wire as grounding point, this is itself grounded at the PSU minus post.
    mazeeff
    Post by mazeeff Sat Oct 29, 2016 12:46 pm
    Good idea. Did you just run the copper ground bus, across the length of the chassis? How did you mount it?
    Mike
    Post by sKiZo Sat Oct 29, 2016 2:33 pm
    Only screw loose here is sitting in the listening chair. What a Face
    Good point though. Another fairly common area of concern is a loose multi-cap. That can cause substantial hum even if all the actual electrical connections are good.
    Honorable mention also to the RCA jacks. Those can loosen up and rotate, shorting out a channel.
    Post by peterh Sat Oct 29, 2016 2:39 pm
    Mike
    I user solder tags : see http://n.manet.nu/vta70/
    ( i think i made a thread about this build, but here is one picture again)
    mazeeff
    Post by mazeeff Sat Oct 29, 2016 4:17 pm
    Mike
    Thanks. Simple enough, and I have the parts on hand!
    Mike
    Post by deepee99 Sat Oct 29, 2016 5:25 pm
    sKiZo wrote:Only screw loose here is sitting in the listening chair. What a Face
    My VPI turntable came that way, loose RCA jacks and you could spin 'em into a short.. But VPI seemed to have used a pneumatic drill to install the plate that held them in. It was a bitch to fix.
    Post by Guest Sat Oct 29, 2016 8:03 pm
    well I have been known to have some loose screws........but yes, I too have been caught out with those loose blighters! It is something that could be easily overlooked!
      Current date/time is Fri Apr 19, 2024 12:24 pm
