    ST-70 no bias and blowing fuses
    drueke
    ST-70 no bias and blowing fuses Empty ST-70 no bias and blowing fuses
    Post by drueke Thu Nov 17, 2016 2:38 pm
    (This is also posted on Audiokarma)
    I'm starting a new thread so I don't hijack another thread and my symptoms might be bit different.
    I recently acquired a nice ST-70, plugged it in and it worked well. I wanted to 'bring it up to date,' replacing the rectifier, electrolytic caps, input jacks and bias test jacks. Did that and now its blowing fuses and bias is 0 volts.
    I've gone back and rechecked solder joints, checked resistor values in the bias circuit path, etc. Checked voltages at several points along the path:
    input voltage: 120V AC
    filament voltage: 6.85 V AC
    AC side of new 1N007 diode: 50 V AC
    DC side: 33 V DC
    input to bias pots: 13.3 V DC
    at eyelets 6 & 21: ~ 7 V DC
    at eyelets 22,23 1 & 2: -.03 to -.20 V DC
    at pin 8 of the EL-34s: 0 V DC
    B+ BTW is ~495 V DC
    Measurements were made with both qa VTVM and a DVM and are fairly close to each other.
    Inputs were shorted during measurements.
    I'm stuck. Any ideas?
    Ray.
    ST-70 no bias and blowing fuses Empty Re: ST-70 no bias and blowing fuses
    Post by Peter W. Thu Nov 17, 2016 3:08 pm
    The first thing that I see is that the DC side of the bias rectifier (that you replaced) should be -65 VDC. The voltage rating of your 'new' diode should be at least 500V. I would suggest a 1N4007 (1A @ 1000V) in any case.
    Keep in mind that a filtered rectifier (which this is) should deliver about 1.4 x the input voltage not considering voltage drop across the rectifier. A 3-stack selenium rectifier has about a 5V voltage drop, making perfect sense at 50 VAC in. With a silicon diode, you should be getting on the order of 70 V.
    Best of Luck With It!
    Did you replace the bias caps as well? I suspect you did, but if so, check your polarity.
    As it stands now, I suspect that your diode is toast, and you might be lucky and that is all it is.
    In the future, take pictures beforehand. Make sure that all your wiring 'makes sense' and is correct. It is _very_ easy to ground a B+ wire to the 4-section filter cap, clearances are not huge.
    Post by Bob Latino Thu Nov 17, 2016 6:42 pm
    DC side: 33 V DC
    If you have 50 VAC on the AC side of the diode and only 33 VDC on the other side, then either the diode is at fault or the two caps that store DC for the bias system are at fault. With 50 VAC on the AC side, you should be getting about 70 to 75 VDC on the DC side.
    If you have the original circuit and you replaced the two 50 uF caps on the 7 lug terminal strip, did you put those caps in like they should be put in with reverse polarity ? The + side of both caps goes on lug #1. The negative side of one cap goes on lug #3 and the other cap's negative side connects to lug #4. Check to see that either or both caps are not reversed.
    Take out all the tubes and turn the amp ON. Measure the negative DC voltage on pin # 5 of each output tube as you rotate the bias pot for that channel. You should get about -20 VDC at one end of the pot and maybe -40 VDC at the other end of the bias pot's rotation. You are not going to get that because you only have 33 VDC to start on the DC side of the diode.
    Post by arledgsc Thu Nov 17, 2016 7:51 pm
    Check polarity orientation of the newly installed bias rectifier diode.  If you have a positive voltage then it is installed backward.  Diode band (cathode) should connect toward the transformer side.
    Post by GP49 Thu Nov 17, 2016 9:39 pm
    Those familiar with electronics can get so "positive voltage-oriented" that building a negative power supply can be counter-intuitive!
    drueke
    ST-70 no bias and blowing fuses Empty Gettin' better!
    Post by drueke Fri Nov 18, 2016 1:07 pm
    Progress!!!
    The diode was backwards (1N4007) and I replaced the caps I had installed with 50uF 100V
    electrolytics. The ones I had originally installed were in correctly but... I now have -71.5 VDC on the DC side of the diode and about +2.2 VDC at the bias jacks with the pots all the way down. The 10k resistors have been replaced with 5.1K and that change got the bias to the 2.2 level from around 4-5 VDC.
    I'll try leaving the amp turned on for a while and see if it still blows fuses using a 3 Amp quick blow fuse rather than slow blow. We'll see what happens.
    Thanks for all the suggestions and assistance - I really appreciate it.
    Its probably been 50+ years since I worked with or troubleshot analogue tube circuits.  Basic electronics training in the Navy went from simple analogue tube amps to simple transistor
    amps to saturation or cutoff, ie 1s and 0s in about 2-3 weeks.  Then it was computers.
    Ray.
    Post by Peter W. Fri Nov 18, 2016 3:20 pm
    If your 3A fuse gets past the turn-on surge, you should be fine for the duration. If it fails an hour later, there is definitely still something going on. An OEM (Factory spec.) 70 is rated at 175 watts, or about 1.5A these days at full output. So a 3A fuse should hold indefinitely - again, once it gets past the surge.
    Best of luck with it. As I am sure you know there are a LOT of after-market opportunities to modify/upgrade this amp.
    drueke
    Post by drueke Fri Nov 18, 2016 3:47 pm
    All fixed (for now)!! Checked the resistance of the bias pots and they are 10K as they should be. Concerned about the bias voltage, I changed to 5.1K resistors in the bias supply, still to high. Ended up with a 10k in parallel with the 5.1k on the ground side and set the bias to ~1.4 volts. The amp is happy and I'm happy!
    Still has a 3amp non-slo-blow and it will stay there for a while. now to enjoy some vinyl.
    Ray.
      Current date/time is Sat Apr 27, 2024 1:01 am
