I tried KT-150s in my ST-120 amp. I could not bias the 150s as I ran out of range on the bias pots. There is too much voltage drop across the bias supply 150K ohm resistors to adequately bias the tubes and they were running hot. As per the datasheet the bias resistors need to closer to 50K ohm. The ST-120 power supply was straining hard to supply the cathode current during this brief trial. LOL... Not recommended. The KT-120s are just perfect for this amp.
A good friend loaned me his Audio Research Reference 75 SE with a spare set of KT-150 tubes. This amp is monster to haul around. Bass is very good (tight) with the Ref 75 but there is not much sparkle on top like I enjoy with the ST-120 with KT-120s. Seems very generic sounding in comparison to the ST-120 though perhaps more accurate and less colored. The Ref 75 is more akin to transistor amps I have tried. I do though need a better balanced linefeed to Ref 75.
So the ST-120 happily lives on in my system. It has seen a few challengers in the past 4 yrs. but has held out and stands proud. Excellent amp Bob and great value!
