    ST-70 Restoration first Power-Up: Blowing fuses........any advice please??
    Doctor Hugocat
    Doctor Hugocat
    ST-70 Restoration first Power-Up: Blowing fuses........any advice please?? Empty ST-70 Restoration first Power-Up: Blowing fuses........any advice please??
    Post by Doctor Hugocat on Sun Nov 20, 2016 1:49 am
    Hi Guys -
    Well I finished my St-70 (VTA PCB) project.....at last.
    I went to power it up tonight and I have a problem. Can anyone advise, please?
    I put a 1amp fast-blow fuse in, and have been following the instructions that came with my VTA Board. I put in JUST the driver tubes first, and they glowed. I powered off, removed the driver tubes and put in the rectifier and Right hand power tubes. The fuse blew. I put in another 1amp and that blew too. I changed the power tubes, tried once more. Blew.
    The rectifier is a NOS and tested good on my borrowed tube tester.
    Can anyone help?? I went over and over the wiring before powering up, and I don't think I've made a mistake. EVERYTHING except output trannys is brand new. THANKS!!
    Tubes4ever
    Tubes4ever
    ST-70 Restoration first Power-Up: Blowing fuses........any advice please?? Empty Re: ST-70 Restoration first Power-Up: Blowing fuses........any advice please??
    Post by Tubes4ever on Sun Nov 20, 2016 2:18 am
    The ST70 should have a 3 amp slow blow fuse. 1 amp is too small.
    Tim L.
    Doctor Hugocat
    Doctor Hugocat
    Post by Doctor Hugocat on Sun Nov 20, 2016 2:37 pm
    Thanks Tim!
    I replaced the 1a with a 3a slow-blow and I just successfully set the LH bias. Gotta go out now but with set RH later. Super-excited!!
    I read somewhere to do first power up with a 1a: I didn't know when to replace that with a 3a.
    Post by Peter W. on Sun Nov 20, 2016 3:53 pm
    Doctor Hugocat wrote:Thanks Tim!
    If one uses a metered variac and has a light touch, a 1A fuse is *just* feasible to start a 70. But, not for actually running it. And I use a very light fuse to test radios after restoration and/or repair - but without the tubes in it. This tests the most basic wiring, especially the transformer. But once the tubes are in, or the rectifier starts to pass B+, that is when the real load begins.
      Current date/time is Thu Jan 23, 2020 5:30 am
