    replacement transformer for an A430 - 431 ok?
    Chris Scott
    replacement transformer for an A430 - 431 ok? Empty replacement transformer for an A430 - 431 ok?
    Post by Chris Scott Thu Dec 14, 2017 3:30 pm
    ...as the title says - will an A431 work as a drop-in replacement for one of my MKII's?
    I'd guess the only difference between the two would be the extra (4 ohm) sec. tap on the 431, but I could be wrong.
    TIA!
    DynakitParts
    DynakitParts
    replacement transformer for an A430 - 431 ok? Empty Re: replacement transformer for an A430 - 431 ok?
    Post by DynakitParts Thu Dec 14, 2017 6:18 pm
    The A-431 will work fine with your MK II amplifier. Just terminate one of the unused taps inside the chassis.
    Kevin
    Post by GP49 Sat Dec 16, 2017 2:03 am
    Or bring the 4Ω tap out to where it can be used. These days the 4Ω tap is probably more useful than the 16Ω.
    Chris Scott
    Post by Chris Scott Tue Dec 19, 2017 12:56 pm
    Ok thanks guys, appreciate you both taking the time to confirm my suspicions...
      Current date/time is Thu Mar 28, 2024 6:47 am
