    6 V bucking transformer
    eickmewg
    6 V bucking transformer Empty 6 V bucking transformer
    Post by eickmewg on Thu Dec 08, 2016 11:09 am
    I'm interesting in either making or buying a 6 V bucking transformer. My wall voltage is a tad over 123 V and I'd like to drop that to around 117 V. So a simple BOM and a diagram of the circuit would be nice. Perhaps better yet, if you have a spare lying around I'd be happy with a purchase. Thanks in advance.
    Bill
    6 V bucking transformer Empty Re: 6 V bucking transformer
    Post by Dave_in_Va on Thu Dec 08, 2016 11:47 am
    I used this site...
    https://robrobinette.com/5e3_Modifications.htm#Bucking_Transformer
    ...and slightly simplified it as I didn't need the larger voltage drop. I have the same same situation as you and this works perfectly. I use the Belkin (Amazon) on/off switch just because I don't see the need for the transformer to be working 24/7.
    I got the box from Amazon, the plugs from Lowes and I think I got the tranny from Mouser.
    I have four of these and also use them for what I consider "delicate" '60's gear (i. e. non-Fender) like Silvertone amps, Vox/Farfisa organs.
    (I know this could be done smaller and more neatly but I went with what I had.)
    6 V bucking transformer Buck1_zpstx06nlyf
    6 V bucking transformer Buck2_zpsnswsys5o
    Post by corndog71 on Thu Dec 08, 2016 11:48 am
    Here's the one I bought earlier this year.
    http://www.mouser.com/search/ProductDetail.aspx?R=0virtualkey0virtualkey166Q6
    I added a 5 amp circuit breaker to mine. I wrote the circuit down somewhere but I'll have to dig it up. It's quirky.
    6 V bucking transformer BB86A2AB-258A-4BA1-88ED-92078658295A_zpsyj8naqoj
    eickmewg
    Post by eickmewg on Thu Dec 08, 2016 2:19 pm
    OK, it looks like a 6.3 V center tap transformer is the way to go. What amperage should I use? I seem to recall folks used to use a 2 A Radio Shack transformer. Is 2A too little? Dave you used a 4 A and Corndog, you used a 6 A transformer. So what to get?
    Post by corndog71 on Thu Dec 08, 2016 2:26 pm
    I made mine bigger than needed just in case. Bigger is better! cheers
    Post by Dave_in_Va on Thu Dec 08, 2016 2:55 pm
    I just went by the Robinette web page which calls for 4 amps. Robinette obviously knows more about it than I do Smile
    wgallupe
    wgallupe
    Post by wgallupe on Thu Dec 08, 2016 4:41 pm
    Could I use one of these to power 2 Mark III monoblocks or is it best to go with one bucking transformer for each monoblock?
    Post by sKiZo on Fri Dec 09, 2016 1:16 am
    I went with 7v 6a ... mostly because I had one in the parts bin ...
    6 V bucking transformer Bucking-transformer
    Wiring is pretty straight forward with a two stage transformer ... careful to test before plugging anything in ... if you wire it up backwards, the output increases.
    6 V bucking transformer Bucker-wiring
    The power strip is nice because it already has an power switch and breaker built right in.
    PS ... the transformer should be able to comfortably handle the max draw of whatever's plugged into it. I run an ST120 and an Eico mono tuber off this one.
    eickmewg
    Post by eickmewg on Tue Dec 13, 2016 6:16 pm
    The bucking transformer is a success. I used a Hammond 546-166Q6 which is a 6.3 V center tap.  I didn't bother with a pilot light or on-off switch for now.  With a wall voltage of 123 V, I can now drop to 119 and 115 V, which should cover me if wall voltage drops or rises a bit.  I even got it wired correctly the first time.  The transformer is 6 A so I should be pretty safe.  Thanks to all for your help.  A fun little project.
    Bill
      Current date/time is Thu Jan 23, 2020 5:30 am
