    Trouble-Shooting my New ST-70 (VTA PCB): Voltages at Pin 5
    Doctor Hugocat
    Doctor Hugocat
    Trouble-Shooting my New ST-70 (VTA PCB): Voltages at Pin 5 Empty Trouble-Shooting my New ST-70 (VTA PCB): Voltages at Pin 5
    Post by Doctor Hugocat on Sun Dec 11, 2016 6:53 pm
    Hey Guys -
    I recently posted a topic about my newly-rebuilt ST070 (with a VTA PCB) giving horrible problems at first startup:
    http://dynacotubeaudio.forumotion.com/t3204-another-problem-with-my-st-70-build-rectifier-tube-flashed-and-now-dead-right-rear-tube-any-ideas
    Well, acting on the excellent advice of a couple of members here (Thanks again)! I double checked my wiring and found no problems. I then looked through the Curcio trouble shooting guide and did the following:
    • Replaced the rectfier with a solid-state one from eBay
      powered up with NO tubes or rectifier: powers up fine.
      Powered up WITH solid-state rectifier: power up fine.
    I then measured the voltages at pin 5 of the power tube sockets (no power tubes) and got this:
    Rear right -43vdc
    Front right -42.2vdc
    Rear left -43vdc
    Front left -43vdc
    This seems within spec, right? Doesn't this rule out the quad cap and power trans?
    So what now? I don't have any way of testing the power tubes and the Curcio guide suggests power tubes could be at fault. SO.....what would my next step be? All the Dynaco manual test points seem to be WITH tubes: and since I can't trust the power tubes, what to do next??
    Thanks!!
    Trouble-Shooting my New ST-70 (VTA PCB): Voltages at Pin 5 Empty Re: Trouble-Shooting my New ST-70 (VTA PCB): Voltages at Pin 5
    Post by peterh on Mon Dec 12, 2016 3:41 am
    As i wrote on audiokarma :
    I would start with a new set of el34, and a new GZ34.
    Tubes are expendable and once flashed may easily flash again.
    But first, double check that the bias resistors ( 10 ohm?) are all healthy, and that the bias
    pots are turned fully in the direction of most negative voltage for all 4 power tubes. This is
    a starting point when installing new power tubes !
    Also power up with shorting plugs on inputs and a proper loading on the output ( speakers or 8 ohm
    power resistor)
      Current date/time is Thu Aug 22, 2019 4:13 am
