    rectifier tubes for VTA ST70
    tubenutr
    Post by tubenutr on Thu Dec 22, 2016 9:37 pm
    I'm sure this topic has been beaten to death, but.............................
    What rectifier tubes can be used in the above mentioned amp.
    Thanks, Mike
    Re: rectifier tubes for VTA ST70
    Post by peterh on Fri Dec 23, 2016 3:44 am
    tubenutr wrote:I'm sure this topic has been beaten to death, but.............................
    Thanks, Mike
    Any 5AR4 / GZ34 will do.
    So will a number of others that might or might function is intended.
    Post by Bob Latino on Fri Dec 23, 2016 4:14 pm
    You can also use a 5U4 tube rectifier in the VTA amps. There will be a slight loss of power by the use of a 5U4 but the amp will work fine ..
    tubenutr
    Post by tubenutr on Fri Dec 23, 2016 5:01 pm
    Thanks Bob.
    Just wanted to know.
    Mike
    Post by Dave_in_Va on Fri Dec 23, 2016 5:25 pm
    High quality NOS 5U4s are widely available at very reasonable prices (like 1/3 - 1/4 that of a 5AR4).
    Tubes4ever
    Post by Tubes4ever on Fri Dec 23, 2016 10:33 pm
    And a 5U4 is notably longer lived than a 5ar4. As Bob noted, your B+ will be a bit lower than with a 5ar4 / GZ34. With a 5ar4 I get about 425 volts with a wall voltage of 120V. I get about 380V with a 5U4. You won't notice the difference unless you play your system really loud.
      Current date/time is Sun Feb 25, 2018 9:40 pm
