    Recommend replacement 2000uf rectifier caps for PAS
    Dry Rub
    Recommend replacement 2000uf rectifier caps for PAS Empty Recommend replacement 2000uf rectifier caps for PAS
    Post by Dry Rub Sat Jan 07, 2017 1:43 pm
    I'd like to replace the selenium rectifier with diodes and replace the larger caps below it while I'm at it. While it's been easy to find info on the diode type to use, I've found so many different comments about what caps and values to use when replacing the two large 2000 uf caps. I'm not interested in a replacement board, just need someone's advice for appropriate replacements. Seems like an increase in uf value is often suggested but I don't want to choose the wrong thing when it comes to the uf or voltage values.
    Links to caps would help too! Thanks.
    Recommend replacement 2000uf rectifier caps for PAS Empty Re: Recommend replacement 2000uf rectifier caps for PAS
    Post by peterh Sat Jan 07, 2017 2:00 pm
    Dry Rub wrote:I'd like to replace the selenium rectifier with diodes and replace the larger caps below it while I'm at it. While it's been easy to find info on the diode type to use, I've found so many different comments about what caps and values to use when replacing the two large 2000 uf caps. I'm not interested in a replacement board, just need someone's advice for appropriate replacements. Seems like an increase in uf value is often suggested but I don't want to choose the wrong thing when it comes to the uf or voltage values.
    You install then either as the original ( needs to fit in the clamps ) or
    much better on one board ( an example below) http://n.manet.nu/tubedoc/PAS_PS-V3.0-Install.pdf
    Post by Guest Sat Jan 07, 2017 2:44 pm
    Last edited by PeterCapo on Thu Dec 03, 2020 11:21 pm; edited 2 times in total (Reason for editing : Voltage rating.)
    Post by j beede Sat Jan 07, 2017 4:40 pm
    Here's the B+ and filament supplies on a single small board that fits where the selenium stack was. I get my caps from Antique Electronic Supply. The diodes from Fry's or Radio Shack.
    Recommend replacement 2000uf rectifier caps for PAS <a href=Recommend replacement 2000uf rectifier caps for PAS Cfde85b3-7084-483a-85ab-8fae5c188075" />
      Current date/time is Fri Mar 29, 2024 12:53 am
