+2
10-E-C
Dahlberg
6 posters
    Experience of 5963 tube
    Dahlberg
    Dahlberg
    Experience of 5963 tube Empty Experience of 5963 tube
    Post by Dahlberg Wed Jan 11, 2017 9:17 am
    10-E-C
    10-E-C
    Experience of 5963 tube Empty Re: Experience of 5963 tube
    Post by 10-E-C Wed Jan 11, 2017 12:14 pm
    Dahlberg wrote:This was an interessting articel.
    http://www.jacmusic.com/nos/ECC82/5963/5963-index.htm
    I run 5963s in my M125s and also in my ST-70. I found some Phillips 5963s that sound wonderful in my M125's and A JAN 5963 in my center position of my ST70. I don't think you can go wrong with the 5963s.
    TM
    Jim McShane
    Post by Jim McShane Wed Jan 11, 2017 1:08 pm
    I would caution however that the 5963 often tends to be microphonic. While they are used in less sensitive positions in Bob & Roy's gear they can still cause you grief.
    Be sure the tubes you get are tested for microphonics!
    Dahlberg
    Dahlberg
    Post by Dahlberg Wed Jan 11, 2017 2:26 pm
    I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
    Rabindu
    Rabindu
    Post by Rabindu Wed Jan 11, 2017 2:44 pm
    I'm using an RCA USN CRC 5963 with black plates and a foil "D" getter of 1958 vintage in the centre voltage amplifier position in my ST-120 with excellent results.
    Also have in the left and right phase splitter/inverter positions a matched pair of RCA JRC-5814A with 3 micas, black plates and a square getter of 1959 vintage. Got these NOS tubes from a reliable seller on ebay.
    Mike Kampman
    Post by peterh Wed Jan 11, 2017 3:40 pm
    Dahlberg wrote:I bought two separate sets of four today, JAN Philips and a set of RCA's. 50euros/set.
    That was expensive ! I hope the sound is accordingly.
    Dahlberg
    Dahlberg
    Post by Dahlberg Wed Jan 11, 2017 4:55 pm
    Do you have a better price ?
    eickmewg
    Post by eickmewg Wed Jan 11, 2017 6:09 pm
    I got some GE 5963's awhile ago. I found them to be rather noisy and I went back to 12BH7's for my ST120.
    Post by peterh Thu Jan 12, 2017 7:05 am
    On ECC82/802 /12au7 ? Yes. 120 swedish crowns, including sales tax.
    Dahlberg
    Dahlberg
    Post by Dahlberg Thu Jan 12, 2017 7:51 am
    Nothing wrong with those prices but this was for the 5963 and the conclusion of the
    articel. I'm guessing you have a different opinion about the virtues of this tube ?
    I'll give you a call for some more tubes.
    Edit: Couldn't find a phone nr on your homepage ? PM maybe ?
    Post by peterh Thu Jan 12, 2017 8:46 am
    Dahlberg wrote:Nothing wrong with those prices but this was for the 5963 and the conclusion of the
    I had 5963 in my vta-70 as delivered. But one of them developed hum after
    some 1000 hours so i replaced them ( no use replacing only one), the remains
    was given to a curious customer for free.
    What did i use ? JJ-ECC82. It still sounds good.
    http://tubular-well.se
    eickmewg
    Post by eickmewg Thu Jan 12, 2017 10:01 am
    I agree that the JJ ECC82 is a very good tube; cheap and quiet.  Unfortunately, I had a trio of these tubes in a plastic bag and my dog managed to pull it off the counter.  By the time I got them back, he had done a  number of the pins on one of them!  I now have a duo Mad
    Post by peterh Thu Jan 12, 2017 10:17 am
    eickmewg wrote:I agree that the JJ ECC82 is a very good tube; cheap and quiet.  Unfortunately, I had a trio of these tubes in a plastic bag and my dog managed to pull it off the counter.  By the time I got them back, he had done a  number of the pins on one of them!  I now have a duo :x
    I hope the dog did not swallow any of the pins, they might puncture the internals.
    At least you have 2 left, you can listen to stereo with them !
      Current date/time is Fri Apr 26, 2024 1:01 pm
