If anyone has performed the RIAA EQ mod to their PAS2, could you please advise on proper capacitor matching, suggested brands, AND parts numbers if you used a vendor ? (ie. Digi-key,...no affiliation.)
Thank you!
Thank you!
8xlaxx wrote:If anyone has performed the RIAA EQ mod to their PAS2, could you please advise on proper capacitor matching, suggested brands, AND parts numbers if you used a vendor ? (ie. Digi-key,...no affiliation.)
Thank you!
Why replace the input selector ? Motivate please.j beede wrote:Regardless of what you do regarding the RIAA circuit... by all means replace your input selector and its associated wiring. If you are still running the stock power supply--that needs to go too.
Replacing the input selector is an ideal time to replace the stock RCA I/O board. This is not a trivial job but makes the PAS perform like a much more modern preamp.
