    PSU caps question
    popesco
    PSU caps question Empty PSU caps question
    Post by popesco Fri Feb 24, 2017 8:59 am
    Hello everybody Smile
    I need an advice from you guys. I have on my way, an old Dynaco st-70. From the start i want to change a few things.
    I will be moving the parts to a new case. I'm going to replace the driver with a VTA board. Change the power transformer so i can later use kt88 tubes.
    Also i want to remove the quad cap and build a small psu board. This is where i need your help.
    I already have 2x82uF 450v, 2x270uF 450v. So, using 40uf - choke - 135uf would be enough to drive the kt88? Should i add more? The VTA board already has 2x47uF and 2x100uF.
    Thanks.
    PSU caps question Empty Re: PSU caps question
    Post by Bob Latino Fri Feb 24, 2017 12:11 pm
    popesco wrote:Hello everybody Smile
    Thanks.
    I don't believe that you need anymore capacitance than what you have listed. Just remember that the last cap in the chain after your 2 X 270 uF in series has to have a "drop-down" resistor of about 2.2K before sending the B+ to the VTA driver board.
      Current date/time is Thu Mar 28, 2024 9:01 am
