    Will a tube cage fit over the Tung-Sol KT120 output tubes ?
    Post by Bob Latino on Mon Feb 27, 2017 9:32 pm
    I have someone that wants to know if a Dynaco tube cage will fit on a VTA ST-120 chassis that uses the Tung-Sol KT120 output tubes. I have no tube cages here to check this out? If anyone is using KT120 output tubes on a VTA ST-120 WITH A TUBE CAGE, let me know if the cage fits on the top without hitting the top of the KT120 ?
    DynakitParts
    ST-70 top cover
    Post by DynakitParts on Mon Feb 27, 2017 9:56 pm
    Bob,
    I don't believe the cover will fit when using the KT120 output tubes. Cover inside vertical clearance is 4.50" from top side of chassis.
    Kevin
    Re: Will a tube cage fit over the Tung-Sol KT120 output tubes ?
    Post by Bob Latino on Mon Feb 27, 2017 10:00 pm
    Hi Kevin,
    Thanks for the info .. I will pass it along ..
    Post by Kentley on Mon Feb 27, 2017 10:08 pm
    The Genalex KT-88 is only 4mm shorter (110mm vs. 114mm) and it fits quite nicely under the cage. The TungSol KT-120, while it will fit, would push the limits. However, if instead of screwing down the cover, you place it firmly in the chassis grooves which gives another half-inch of clearance, it will be quite stable. If needed, cardboard or wooden shims can be easily fashioned to increase stability.
    I've been using the cage this way for well over a year. Works like a charm.
    Using the cage in this manner allows me to adjust bias, and remove the cage for any reason without a screwdriver or hernia.
    Post by Maintarget on Mon Feb 27, 2017 11:08 pm
    Bob I have an ST-120 I bought from you and I'm using the KT-120 tubes using and the ST-70 cover i bought from DynaKitParts it fit's just fine and looks great.
    PS I'm not using any shims or anything elese.
    Last edited by Maintarget on Mon Feb 27, 2017 11:10 pm; edited 1 time in total (Reason for editing : additional info)
      Current date/time is Mon Jan 22, 2018 4:23 am
