    VTA-70 to VTA-120 conversion
    xlr8
    VTA-70 to VTA-120 conversion Empty VTA-70 to VTA-120 conversion
    Post by xlr8 Tue Mar 30, 2010 10:48 am
    Hello,
    Well folks, I have fallen in love with my 2 70's in triode mode. Almost regardless of the music I'm listening to, I find myself switching back to triode mode and leaving the amps alone. The speakers I built are extremely revealing and the difference between triode and pentode modes is VERY apparent. Although sensitive enough for the 70's, I never really thought I'd run them on just over 15 watts. From what I can tell, it seems that upgrading the transformers, adding another choke and some more caps in the power supply and I've got myself a VTA 120? What am I missing? It may be years before I ever do this...
    wolverine
    VTA-70 to VTA-120 conversion Empty Re: VTA-70 to VTA-120 conversion
    Post by wolverine Tue Mar 30, 2010 1:06 pm
    Same here in respect to triode mode, I have 4 amps and all 4 are now hard wired in triode. For my ears personally, triode mode sounds best no matter what I want to listen to. I use Klipsch Heresey's and KG-4's, I like the horn loaded mids, seems to add more life. Using these speakers and running in triode mode gives me all the sound I could possible want, I don't miss the 60% drop in power one bit myself. A switch to go between triode and pentode to me is simply not needed, I have no inclinations to listen to the pentode mode of the amps.
    wolverine
    Post by Bob Latino Wed Mar 31, 2010 6:06 am
    xlr8 wrote:Hello,
    To change an ST-70 to an ST-120 you need ...
    1. The three transformers from the ST-120
    2. An extra choke
    3. The SCM (Supplementary Cap Module)
    4. A set of ESL (Equivalent Series Induction) caps
    5. Some changes to the components on the VTA driver board
    You would also have to drill four 9/32 inch holes in a stock ST-70 chassis to accomodate the larger output transformers. If you have one of my chassis you wouldn't have to drill the chassis since they are dual drilled for either the ST-70's or the ST-120's output transformers.
      Current date/time is Mon Mar 18, 2024 11:37 pm
