    Tube rectifiers
    tubenutr
    Tube rectifiers
    Post by tubenutr on Thu Mar 09, 2017 2:43 am
    Hey, I've only had one tube fail and that was after a power blip.
    Looked around and found a non-clamping GFCI plug and hasn't happened again.
    I've tried quite a few tubes from Europe, the US and China.
    Currently using a Chinese tube by Langrex of GB.
    Works like a charm. For what this is worth.
    Mike
    Re: Tube rectifiers
    Post by j beede on Thu Mar 09, 2017 1:39 pm
    Better order spare 5AR4s after that post. Mr. Murphy is predicting an onslaught of failed rectifiers in your future :-)
    I have had good results with SOVTEK 5AR4. I attribute some of this to the series 1n4007 that many of us have inserted ahead of the 5AR4/GZ-34--the so-called "yellow sheet" modification. I also attribute it to keeping the load on my rectifiers on the light side. I suppose that's why my MkIIIs have such weak bass  Rolling Eyes
    Yellow sheet rectifier mod
    tubenutr
    Re: Tube rectifiers
    Post by tubenutr on Thu Mar 09, 2017 4:48 pm
    j beede wrote:Better order spare 5AR4s after that post. Mr. Murphy is predicting an onslaught of failed rectifiers in your future :-)
    I have enough to last for years.
    Gregg R.
    Re: Tube rectifiers
    Post by Gregg R. on Fri Mar 10, 2017 5:20 am
    I have also tried the Chinese/Shuguang 5AR4 from Langrex of the UK. It sounded real good, until it failed after just 3 months.
    As far as reliability, I have had the best luck with the Weber WZ68. However, I prefer the sound of tube rectification in my Latino VTA-70. An actual vacuum tube in that position seems to provide better flow and tactile presence to the music. Solid-state rectifiers sound more mechanical to my ears. It's a close call, however; most people will go with reliability.
    For the last week, I've been using a Mullard GZ33, purchased from Upscale Audio. It sounds good, but hasn't quite bowled me over. I expected more for $100. The Shuggie actually sounded the best of all the tube rectifiers I've tried: Genalex U77, JJ 5AR4, Sovtek, NOS GE 5U4G. The Sovtek also failed after a couple months.
    My advice, put your money into the center tube of the VTA board, then the power tubes, then the driver tubes, lastly the rectifier.
    Re: Tube rectifiers
      Current date/time is Thu May 24, 2018 9:18 pm
