    How to use two VTA ST-70's?
    Post by Dave_in_Va on Thu Mar 30, 2017 10:31 pm
    If you had two of them and wanted to use one for each channel, how would you hook them up?
    (Sorry, too late for me to figure this out for myself.)
    Thanks in advance.
    Re: How to use two VTA ST-70's?
    Post by peterh on Fri Mar 31, 2017 1:35 am
    Dave_in_Va wrote:If you had two of them and wanted to use one for each channel, how would you hook them up?
    Thanks in advance.
    Parallelling is really no option as the tubes are probably not that equal. It might
    be ok for a PA system, but if hifi is the goal - no.
    I would sell both and buy a vta120 for the money. Or change speakers to
    something more sensitive. Or buy 2 MkIII .
    Post by Peter W. on Fri Mar 31, 2017 6:20 am
    Thanks in advance.
    Do they not have a mono-stereo switch?  If so, that is your answer.
    Each individual amp becomes, effectively a 4-output-tube mono amp.
    Post by peterh on Fri Mar 31, 2017 6:33 am
    Thanks in advance.
    Each individual amp will get 2 output's that might be slightly different. To drive
    2 separate speakers it will work, but if driving one speaker chances are that
    the amps will counteract each other due to differences in amplification.
    Post by Bob Latino on Fri Mar 31, 2017 6:59 am
    Thanks in advance.
    The best thing to do is explained at the links below in a couple of forum posts from 2011
    Biamping with two ST-70's ...
    The reasons why NOT to run the amps in mono are explained very well by forum member GP49 at the link below ..
    Running ST-70 amps in mono ?
    Post by Dave_in_Va on Fri Mar 31, 2017 7:30 am
    Thanks guys. I really don't need more power. I was just curious more than anything.
      Current date/time is Sun Feb 25, 2018 9:38 pm
