+4
GreggW
buschfsu
8 posters
    power switch options
    buschfsu
    power switch options Empty power switch options
    Post by buschfsu Mon Mar 27, 2017 4:33 pm
    hello all
    so a power switch on the back of my st-70 is not ideal. reaching over hot tubes in a shelf is a hassle. couple options i see...
    relocate to the mono/stereo switch (runs 120v through the critical audio signal traces... sounds bad)
    use a relay at the mono/stereo switch but since i only have the heater tap i could run a 6v relay to control the 120v power in the back.
    use a 12v trigger signal from my reciever to auto turn on/off but this would require a whole new circuit with relay
    anyone done this?
    thanks
    jason
    power switch options Empty Re: power switch options
    Post by peterh Mon Mar 27, 2017 7:20 pm
    buschfsu wrote:hello all
    anyone done this?
    thanks
    jason
    Yes, bet an even better solution: use a SSR ( solid state relay)
    Se http://n.manet.nu/vta70/ pictures from my vta70 build.
    Some comments:
    the SSR is connected in parallell with the existing power switch, thus
    amp may be used in absence of external control voltage.
    The control is connected with a isolated rcaplug mounted in the unused fuse
    As control 12V DC from preamp is used , but SSR accepts 3-32V
    I also mounted an IEC connector instead of the "knot-on-power-cable".
    Post by Bob Latino Mon Mar 27, 2017 8:07 pm
    If having the power switch on the rear of the amp is a problem in your VTA ST-70 or VTA ST-120, you can plug the amp into a power strip. Keep the power strip towards the front of your music system. You leave the amp's power switch in the ON position and just turn the amp on or off using the power strip's AC switch.
    GreggW
    GreggW
    Post by GreggW Mon Mar 27, 2017 8:18 pm
    I moved the on/off switch from the back to the "mono/stereo" position. I ran the twisted wires carefully along the bottom of the chassis. There is NO hum. I think Bob's idea is best, but I do like the power switch in front.....
    Post by peterh Tue Mar 28, 2017 5:05 pm
    One very nice feature of the SSR device is that it connects and disconnects at the zero crossing.
    Thus there is no turn on pop ( won't be heard in a tube amp but may disturb other equip. ) and no turn off pop . This is something a hardware switch or magnetic relay cannot do.
    Post by corndog71 Wed Mar 29, 2017 10:12 am
    That SSR is an interesting option that I've never seen before. I see Digikey has them for around $48.
    mazeeff
    Post by mazeeff Wed Mar 29, 2017 12:05 pm
    I purchased one of these, to solve my problem. Never have to leave the chair! This one is non-latching, which leaves the relay off, in response to a power outage.
    https://www.amazon.com/gp/product/B001Q9EFUK/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
    Post by peterh Wed Mar 29, 2017 12:21 pm
    corndog71 wrote:That SSR is an interesting option that I've never seen before.  I see Digikey has them for around $48.
    You may find these significantly cheaper :
    http://www.ebay.com/itm/Groove-End-LED-Indicator-Light-DC-AC-Solid-State-Relay-10A-24-480VAC-3-32VDC-/291557662911?hash=item43e230e0bf:g:cU0AAOSw~AVYuL-K
    Post by corndog71 Thu Mar 30, 2017 10:05 am
    That is considerably cheaper. Unfortunately they do not ship to the US.
    Post by corndog71 Thu Mar 30, 2017 12:47 pm
    Found cheaper ones on ebay.
    Post by deepee99 Thu Mar 30, 2017 12:51 pm
    mazeeff wrote:I purchased one of these, to solve my problem. Never have to leave the chair! This one is non-latching, which leaves the relay off, in response to a power outage.
    That "never have to leave the chair" part sold me!
    I bought two.
    And BTW, those tubes only give you the heat treatment when you're turning the rear switch OFF.
    Post by peterh Fri Mar 31, 2017 7:30 am
    I have a power switch in mind that i never got any chance to implement;
    it consist of 2 buttons one red and one green, 1 diode+ resistor+uF cap and a 9V battery + a green LED with resistor, All energizing an SSR with the few mA that the SSR needs
    Function is described as :
    the green button connects the 9v battery + to the control line connected to the SSR, thus
    energizing the SSR. This starts teh amp.
    When amp starts, a suitable AC ( filament ?) is rectified with the diode, smoothed by the uF and
    keeping the control line energized, the button may be released at this moment.
    If mains should fail ( brownout or simular) the amp won't restart.
    Stopping the amp is done with the red switch that shorts the control line to ground.
    A green LED also powered from the amp indicated that the amp is on .
    The 9V battery might be replaced by a few Nimh batteries, these could be trickle charged by
    the holding voltage, but honestly i thing this makes life more complicated. A single 9V batter
    used one second each time amp is started will last for a long time.
    The uF cap should be large enough to keep the recitfied AC above 3V, but small enough to
    make maneuvers reasonable, a guess is 10uF 25V
    Sadly enough all amps i have used last decennium has a mechanical switch, thus i have not
    got the motivation for the above thing.
    Ernstmach
    Ernstmach
    Post by Ernstmach Fri Mar 31, 2017 10:03 am
    When I assembled my MK III's I used one of these in each amp: https://www.amazon.com/gp/product/B01BR3B9XU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Have worked very well. These have seen daily use for the last year with no problems. They are mounted in the front of the chassis.
      Current date/time is Thu Mar 28, 2024 6:16 am
