    PAS Cabinet Mounting Hardware
    boycephoto
    Post by boycephoto on Thu Apr 01, 2010 12:35 pm
    I bought a PAS a long time ago. It came with a Dyna walnut cabinet but it was not attached. Would someone tell me what the stock Dynaco mounting hardware is and how it was used. Thanks in advance. Very Happy
    Dave
    DynakitParts
    Re: PAS Cabinet Mounting Hardware
    Post by DynakitParts on Sat Apr 03, 2010 9:31 am
    Hi Dave,
    From memory..The CAB-1 has (2) counter sunk holes in the base
    of the wood (veneered) cabinet. These should correspond with the PAS
    bottom cover which has a total of (6) holes of which (4) are for the
    rubber feet. The (2) smaller holes are the holes that you will use for
    cabinet. The (4) rubber feet are removed from the PAS but retained and
    remounted to the wood cabinet if you choose with suitable wood screws.
    The CAB-1 kit included a peel & stick felt like strips..maybe (2) for
    use as a spacer and protection from scratches to the PAS top cover as
    you slide the unit into the cabinet. These strips can be afixed to the
    under side of the top portion of the cabinet...One near the front and
    one near the back. Foam rubber, cork etc should work fine.
    You will need (2) wood or sheet metal screws.I believe # 8 screws of
    suitable lenght to secure the wood cabinet to the chassis, but not to
    long as to contact the second tier circuit board chassis or underside
    componets/wiring. These (2) screws should include flat washers.
    You will need to fuss with this a bit to get it level & evenly spaced
    in the cabinet.
    Kevin
    boycephoto
    Post by boycephoto on Sat Apr 03, 2010 9:42 am
    Thanks Kevin,
    That's just what I am looking for.
    Dave
      Current date/time is Wed May 16, 2012 7:36 pm
