    I did the unthinkable: VTA ST120 powered amp on with NO speakers connected!
    Keverdawg
    Post by Keverdawg on Mon May 08, 2017 5:45 pm
    I did it, my fault. I powered on my VTA ST120 with KT120s in it. switched it right off. It was maybe on for 10 seconds at the most. I was leaning over the amp to turn it on and I was looking for tubes to light up. I had installed the warmup timer when I built the amp. Tubes began to light up and I noticed some arcing in the right rear power tube. I immediately turned the power off. I looked for what I had done and saw that the speaker wires weren't connected. I hooked them up and turned the amp back on. I didn't sound good and had much less power. The amp was stored for about a year and I had just bought a tube preamp to put with the amp. l played one album side and I also checked out a FM tuner to it and tried it out. The sound was getting worse so I thought it was time to reset the bias on the Tung Sol KT120's. I wrote Bob Latino to asked about the biasing procedure as it had been a year or more since I fired up this amp. This is what I got:
    Front left biased fine at .500 VDC
    Front right biased at .500 VDC
    rear Left biased could not be set the meter read 18.5 VDC turnd all the way down CCW on pot.
    Rear right same as rear left.
    What did I break? Rectifier tube? Power Tubes? or all.
    Bob help me please...
    Re: I did the unthinkable: VTA ST120 powered amp on with NO speakers connected!
    Post by Bob Latino on Mon May 08, 2017 6:29 pm
    Keverdawg wrote:I did it, my fault. I powered on my VTA ST120 with KT120s in it. switched it right off. It was maybe on for 10 seconds at the most. I was leaning over the amp to turn it on and I was looking for tubes to light up. I had installed the warmup timer when I built the amp. Tubes began to light up and I noticed some arcing in the right rear power tube. I immediately turned the power off. I looked for what I had done and saw that the speaker wires weren't connected. I hooked them up and turned the amp back on. I didn't sound good and had much less power. The amp was stored for about a year and I had just bought a tube preamp to put with the amp. l played one album side and I also checked out a FM tuner to it and tried it out. The sound was getting worse so I thought it was time to reset the bias on the Tung Sol KT120's. I wrote Bob Latino to asked about the biasing procedure as it had been a year or more since I fired up this amp. This is what I got:
    Yes - You should never turn the amp on without speakers attached. The amp is expecting a "load" on the speaker posts and sometimes "things can happen" when you don't have speakers connected. You didn't take out the rectifier. If you took out the rectifier, you would get no bias voltage on any of the 4 bias measuring points ..
    1. With the amp OFF, measure the RESISTANCE to chassis ground at the 4 bias measuring points. Yes - you normally have the amp ON and you are normally measuring DC volts but this time measure the RESISTANCE to chassis ground with the amp OFF. You should get about 10 ohms at all 4 bias measuring points. If one or more of the 10 ohm resistors are blown, you will get no reading or a very high reading on one or more points and the bad resistor(s) must be replaced.
    2. Center the 4 bias pots. Take off the bottom cover. With all tubes out of the amp turn the amp ON and measure the DC voltage on pins 5 and 6 of all output tubes. You should get -50 to -60 VDC at all points. Pins 5 and 6 have a 1000 ohm 1 watt resistor across the two pins.
    Let us know what you find ?
    Keverdawg
    Post by Keverdawg on Mon May 08, 2017 8:52 pm
    Will do Bob. Thanks for jumping on and the help. I will let you know. It will be in a couple of days. I moved the amp to a prestige place at the cabin an hour away.
    Kevin
    Keverdawg
    Post by Keverdawg on Thu May 11, 2017 10:10 pm
    Bob,
    I just checked the impedance on the output tubes as asked and here are the results:
    FL open
    RL 10.12 Ohms
    FR 10.0  Ohms
    RR 3 mOhms
    Voltages on Pin 5 & 6
    FL -60VDC -60VDC
    RL -58.8VDC -58.8VDC
    FR -63VDC -63VDC
    RR -61.5VDC -61.4VDC
    I hope there is some good news in there. I am guessing at best a couple of resistors. I wanted to add that before I did the measurements I replaced the 5AR4 tube diode with a WZ34 Weber Cap.
    Another question as I was searching I thought I read that someone recommended using the WS-1 Weber. Thanks Bob!
    Kevin
    Last edited by Keverdawg on Fri May 12, 2017 9:50 am; edited 1 time in total (Reason for editing : I left out information)
    Post by Bob Latino on Mon May 15, 2017 4:17 pm
    If your readings are correct, then two of those 10 ohm 2 watt resistors should be replaced. The FL and the RR. If one of those resistors reads as open and the other 3 megohms, then those two resistors have to be replaced.
    Keverdawg
    Easy enough!
    Post by Keverdawg on Tue May 16, 2017 8:34 pm
    Bob Latino wrote:If your readings are correct, then two of those 10 ohm 2 watt resistors should be replaced. The FL and the RR. If one of those resistors reads as open and the other 3 megohms, then those two resistors have to be replaced.
    Will do Bob. Thanks for the help. I will post results.
    kevin
    Post by arledgsc on Wed May 17, 2017 9:09 am
    Bob Latino wrote:1. With the amp OFF, measure the RESISTANCE to chassis ground at the 4 bias measuring points. Yes - you normally have the amp ON and you are normally measuring DC volts but this time measure the RESISTANCE to chassis ground with the amp OFF. You should get about 10 ohms at all 4 bias measuring points. If one or more of the 10 ohm resistors are blown, you will get no reading or a very high reading on one or more points and the bad resistor(s) must be replaced.
    Excellent debugging steps Bob. I've had the 10 ohm cathode resistors smoke on power tube failures and measuring them with no power at the bias test points is obviously easy.  Never realized that before until you mentioned it.  Sure beats pulling the amp out of service for surgery.  For fun I measured my ST120 resistors with power off and yup a little more that 10 ohms at the four places.
    Post by tubes4hifi on Mon May 22, 2017 8:08 pm
    one of the reasons I don't agree with using 1 or 2 or 5w resistors for the 10 ohm cathodes. At normal bias, those resistors could be 1/20 watt. So a 1/8 or 1/4 watt is more than plenty.
    I'd rather replace a 10c resistor than a $50 tube anyday!
    Post by Bob Latino on Mon May 22, 2017 8:16 pm
    tubes4hifi wrote:one of the reasons I don't agree with using 1 or 2 or 5w resistors for the 10 ohm cathodes.   At normal bias, those resistors could be 1/20 watt.  So a 1/8 or 1/4 watt is more than plenty.
    I disagree somewhat with Roy here. I have found that a 2 watt resistor will take a little abuse but will blow every time if the tube has a dead short. As to Roy's other comment about the $50 tube .. In nearly all cases the tube is at fault and there is no sense in saving a bad tube.
      Current date/time is Wed May 23, 2018 6:53 am
