    stepped attenuator cable length
    rymi
    Post by rymi on Wed Jun 07, 2017 10:17 pm
    question for those using the stepped attenuator with the vtast70.
    how long of interconnects can you get away with between your source (phono, cd etc) and the attenuator?
    Dogstar
    Re: stepped attenuator cable length
    Post by Dogstar on Thu Jun 08, 2017 1:20 am
    Which stepped attenuator are you talking about and exactly how do you intend on connecting your source to your amp? Directly or through a preamp?
    Post by peterh on Thu Jun 08, 2017 3:51 am
    rymi wrote:question for those using the stepped attenuator with the vtast70.
    It depends on the output characteristics of the sources.
    And "phono", an unamplified cartridge cannot be used without a riaa-amp, thus it's the
    output characteristics of the riaa-amp used that is importent.
    Post by Bob Latino on Thu Jun 08, 2017 9:16 am
    I have used the VTA stepped attenuator with cable lengths up to 3 meters with no issues. After maybe 4 to 5 meters the capacitance of the interconnect cables can act as a low pass filter which can restrict high frequencies a bit. Personally, I think that you would have to go somewhat longer than 5 meters and maybe as long as 10 meters (almost 33 feet) before you even noticed any attenuation of the high frequencies from long interconnects ..
      Current date/time is Sun Jul 15, 2018 11:04 pm
