    Mono/stereo PAS control
    Pillo69
    Post by Pillo69 on Wed Jun 14, 2017 1:34 pm
    I would like to replace the mono/stereo selector of the PAS with an Off/On switch.
    How should the connection?.
    Should any component be introduced?.
    Thanks for your attention.
    Re: Mono/stereo PAS control
    Post by tubes4hifi on Thu Jun 15, 2017 6:40 pm
    you can replace the rotary blend switch with a simple DPDT toggle or slide switch (just like the one used for SOURCE/TAPE).
    For mono, you can use a couple of 4.7K resistors, one from left, one from right, to sum the signals together for mono.
    Pillo69
    Post by Pillo69 on Fri Jun 16, 2017 4:15 am
    Thank you very much.
      Current date/time is Thu Jul 19, 2018 11:32 am
