Hi , I am sitting in a room that is 11'8" X 11' 10" X 92" high . One 11'8" wall is only 5' 6" long . So I,m in a box with 3 1/2 walls . I truly need a bit of advise . Had same equipment in bigger room . and yes smaller too. I have to turn the bass all the way down . I once heard of a big bump around 160 cycles that mess's up the mid range due to the cube . standing waves . . . It sounded so much better in the job RV I was in . I need a cheap way to address this. I am sure knocking out the half wall would work . the room would then be aprox 12 X 19 . I have little to offer but kind thx.
Room influence /Dreaded Cube ?
Kentley- Posts : 496
Re: Room influence /Dreaded Cube ?
First, Scott, you should probably relocate this post to the Forum Basket, as this is where only those members interested in photos go, as a rule.
I have a couple of ideas for you, but before I share them, I'd like to know what the floor and walls are made of, and whether this room is furnished at all or empty. Does it double as space for any other purpose?
