What is the voltage rating of the transformer used on the vta st70?
Is there a temperature rating on them as well?
I am curious because I find its hot after and hour or so. I figured the beefier transformer would be much cooler than my old stuff. most of which runs very hot. So hot you couldn't keep your hand on some of them for 5 seconds without injury.
The VTA ST70 also runs hot after about an hour, but less so than old gear... I could keep my hand on it at the end of a listening session for 5 seconds but little more than that would likely burn. I haven't measured it yet with a thermometer.
Line voltage at my house is usually right on 120. Im running a pair of 8 ohm speakers.
