+3
BNR_1
7 posters
    Mystery ST-120 Problem, Solved
    Mystery ST-120 Problem, Solved Empty Mystery ST-120 Problem, Solved
    Post by arledgsc Wed Jul 19, 2017 4:59 pm
    I listened to my ST-120 this morning for 4-5 hours. Switched it off and back on about one hour later. After it re-warmed a bit I decided to check the bias voltage. The two left tubes read a little high at .525v (.500 normally). Then probing right front tube bias and 0.00v! I looked at the tube and the heater was stone cold!
    See if you can deduce the reason why after the following symptoms.
    - No visible heater glowing on right front KT-120
    - Right rear KT-120 heater looked OK
    - So do the right phase inverter and center tube heaters.
    - The Rt front tube heater pins 2 - 7 measured 1.9 ohms DC and no different than another KT-120
    - Swapping right front/ rear tubes and no help
    - Pulled the tube and measured heater voltage (6.6v AC) on right front tube socket pins 2 & 7. (This one had me fooled)
    - Retention all octal socket pins (no help)
    - Threw a KT-88 in right front socket and (no help).
    Time to open up the patient and have a look. And what I found was a classic cold solder joint on R/F pin 2 socket. Made enough contact to measure voltage with a high impedance meter. The down stream small signal tubes had a connection via enough solder to bridge the two wires. But the wires were losing contact with the socket pin. Some wire redress and solder and good as new.
    Mystery ST-120 Problem, Solved Cold_s10
    Mystery ST-120 Problem, Solved Empty Re: Mystery ST-120 Problem, Solved
    Post by Peter W. Wed Jul 19, 2017 5:03 pm
    Some sloppy wiring visible.
    In many years and thousands of items, I have never done a complete examination and *not* found a soldering fault of some nature - including in kits of my own building.
    Post by arledgsc Wed Jul 19, 2017 5:22 pm
    It has worked for almost 5 years. But I thought later that probably installing tubes over the years moves the pins around and a weak solder joint will eventually fail.
    BNR_1
    Post by BNR_1 Wed Jul 19, 2017 11:13 pm
    Just curious but that red wire about an inch away from the socket pin you point out looks like the insulation is melted away exposing copper.
    Post by arledgsc Thu Jul 20, 2017 6:46 am
    Good eyes... The insulation melted on the red wire is due to another repair on the socket replacing the 10 ohm cathode resistor.
    I have since started using Kapton tape to mask components in delicate, cramped area. Kapton tape doesn't melt and provides a shield from wandering soldering tips.
    Post by deepee99 Thu Jul 20, 2017 9:58 am
    Peter W. wrote:Some sloppy wiring visible.
    The reality we older geezers must face is that our eyesight ain't what it used to be, no matter how well-corrected it is by lenses & etc. Much brighter lighting in the work area than what used to be adequate will help reduce the slop factor. So will a second pair of younger eyes checking your work.
    Post by Peter W. Thu Jul 20, 2017 10:16 am
    The reality we older geezers must face is that our eyesight ain't what it used to be, no matter how well-corrected it is by lenses & etc. Much brighter lighting in the work area than what used to be adequate will help reduce the slop factor. So will a second pair of younger eyes checking your work.[/quote]
    Three articulated lights over the workbench - one with a 4x optical grade magnifier. And point-source LED clamp-on light at hand. Yes, light is good!
    Post by arledgsc Thu Jul 20, 2017 10:24 am
    I hear you Deepee and Peter.  My old eyes need help.  I bought this microscope a few years ago and the best investment for working on electronics especially fine pitch parts.
    Mystery ST-120 Problem, Solved Img_0610
    BNR_1
    Post by BNR_1 Thu Jul 20, 2017 3:45 pm
    arledgsc wrote:Good eyes... The insulation melted on the red wire is due to another repair on the socket replacing the 10 ohm cathode resistor.
    Have you considered PTFE (aka Teflon) tubing?
    Post by arledgsc Thu Jul 20, 2017 4:09 pm
    Yes I have Telfon wires and are wonderful. Easy to strip insulation, and resists burning/ melting. Good stuff. Parts Connexion has a good house brand PTFE hook-up wire. Ag plated, lots of gauges. and by the foot.
    Post by Peter W. Thu Jul 20, 2017 4:16 pm
    Post by deepee99 Thu Jul 20, 2017 9:46 pm
    Peter W. wrote:http://www.oldworldaviaries.com/text/styles/teflon.html
    Also cats & dogs.
    It's why I only cook with cast iron. Could be problematic as an insulator, though . . .
    pedrocols
    pedrocols
    Post by pedrocols Fri Jul 21, 2017 8:25 pm
    Cold solders are a pain. I found one myself after using my amps for over a year. I noticed that one of the power tubes was not turning up. Re flowed the solder and good to go!
    Post by deepee99 Fri Jul 21, 2017 8:47 pm
    Can't recall if it's in the VTA Destruction Manuals or just sort of passed-along wisdom from guys on this board, but even if they're working great, after the first year or so of use, turn them upside down and re-flow the solder, esp. around the sockets and ground lugs.
    Post by Bob Latino Fri Jul 21, 2017 9:18 pm
    pedrocols wrote:Cold solders are a pain.  I found one myself after using my amps for over a year.  I noticed that one of the power tubes was not turning up. Re flowed the solder and good to go!
    After many HOT/COLD (expansion/contraction) cycles sometimes a solder connection can go partial. It looks good on the outside but under the solder the connection is not solid. Sometimes I get an Email > "The amp plays great for the first 15 minutes and then the (right or left) channel cuts out/crackles/hums etc." This symptom is almost always a bad solder connection. Look over all the connections on that channel and resolder any connection that looks suspicious (connection not shiny, small amount of solder or NO SOLDER on the connection). Sometimes a magnifying glass is helpful to look for suspicious solder connections, especially for those of us with older eyes ..
    Post by arledgsc Sat Aug 05, 2017 10:23 am
    I had the same right front tube socket not light off the filaments this morning.  Pins 2-7 measured 6.6Vac.  Must be pin contact so I cleaned the socket pins with TechSpray flux remover and it appears the pins had some oxidation.  Re-tensioned the pins again.  Working OK now!
    But you can see see the oxidation removed on the end of the pipe cleaner.   Pins swabbing will be on my next maintenance schedule.
    Mystery ST-120 Problem, Solved Img_0710
    Post by sKiZo Sun Aug 06, 2017 4:03 pm
    I've gotten into the habit of crimping tube tabs after inserting the wire and then soldering it. Extra mechanical strength helps. Trade off is that it can be a bit of a PITA if you have to change the wiring,but how often does that happen?
      Current date/time is Fri Mar 29, 2024 3:47 am
