    How to properly house-wire your sound system?
    Post by deepee99 on Tue Aug 22, 2017 1:52 pm
    AC from the wall drives all such equipment.
    I'm open to sage advice on this subject. This does not apply specifically to VTA gear, but to any multi-component hi-fi sound-system (Bose Radio owners, move on, nuttin' to see here).
    I will start with my oft-harped-on belief that the best way is to dedicate a grounded wire of Romex from a dedicated 20-amp breaker to a grounded manual-reset GFCI outlet that only the hi-fi gets to use. Nothing else gets to play on that line.
    Further, what say ye? No talk of floating grounds or interconnects. Those are separate issues.
    Dogstar
    Re: How to properly house-wire your sound system?
    Post by Dogstar on Tue Aug 22, 2017 5:58 pm
    That's sounds like the best way to supply power to the sound system. But until I win the 650 million dollar lottery the outlets in the walls I currently have will have to suffice.
    Post by deepee99 on Tue Aug 22, 2017 6:21 pm
    Dogstar wrote:That's sounds like the best way to supply power to the sound system. But until I win the 650 million dollar  lottery the outlets in the walls I currently have will have to suffice.
    Price of 50 feet of Romex: $30: https://www.amazon.com/Southwire-28828222-2WG-Wire-50-Foot/dp/B000BQSL3G/ref=sr_1_1?ie=UTF8&qid=1503439204&sr=8-1&keywords=12+gauge+romex
    Price of hospital-grade outlet: $8.73: https://www.grainger.com/product/52JL81&AL!2966!3!50916778077!!!g!93711479157!?gclid=EAIaIQobChMIxaLlze_r1QIVRpN-Ch2p3wQZEAQYASABEgK9M_D_BwE&cm_mmc=PPC:+Google+PLA?campaignid=175664997&s_kwcid=AL!2966!3!50916778077!!!!93711479157!&ef_id=WP9lDAAAAb6Ur9p4:20170822221840:s
    Price of manual-reset GFCI, about $30: http://development.towermfg.com/gfci-in-line/
    Price of 20-amp circuit breaker for the panel, about $27. https://www.grainger.com/product/1D234&AL!2966!3!50916778317!!!g!81032185797!?gclid=EAIaIQobChMI-rmM8-7r1QIVgzRpCh2H6QaHEAQYBCABEgJnH_D_BwE&cm_mmc=PPC:+Google+PLA?campaignid=175664997&s_kwcid=AL!2966!3!50916778317!!!!81032185797!&ef_id=WP9lDAAAAb6Ur9p4:20170822221549:s
    So for about $100, you're all in.
    And you can use any existing outlet box. Just yank all the extraneous stuff from that circuit and stick it on another breaker. I was giving you the Cadillac solution, but still, no need to win the lottery. Hire an electrician to do it, which adds another $100 maybe you're still well within lottery budget. Two-thirds of his cost of this is the labour involved in pulling wire. Offer to help. It's not rocket science.
    Again, your hi-fi set-up, whether VTA, Marantz, MacIntosh, will thank you.
    Post by Peter W. on Wed Aug 23, 2017 8:50 am
    When I travel, I carry a 1900-box containing a 20A motor-rated single-pole switch, and a wet-location-rated 20A GFIC receptacle. This brings all my 'grounds' to one location when I set up the clinic and the transmitters. And, I do verify that ground.
    And as I am typically working "outside", albeit under roof, I run all the clinic patients and test instruments through a metered Iso-Variac. Asphalt is not as conductive as concrete, but there is, often enough, water around. Like this:
    https://images.reverb.com/image/upload/s--JNw-g46---/a_exif,c_limit,e_unsharp_mask:80,f_auto,fl_progressive,g_south,h_620,q_90,w_620/v1480359327/ejbdtdssabtfngtmujtd.jpg
    Shameless plug: http://www.dvhrc.com/kutztown.html
    As for the systems at home: What Dave said!
    pigface
    Post by pigface on Wed Aug 23, 2017 6:59 pm
    A few years ago I bought a Krell amp to replace my old Carver , I wanted a quality amp for my power hungry Infinity speakers , the Krell manuel said it should have it's own dedicated 20 amp line ! So I actually ran two 20 Amp lines from the box over to where my stereo is kept .  One for the amp and the other for everything else . No hum problem with this set up . It was just a couple new breakers  a roll of romex and a couple quality outlets , also I put a on - off switch on the one line so I don't have to reach around the back of the amp to turn the power switch on . It was just a couple hours work . Although It was a PITA to drill through 5 or 6 inches of cement by the fireplace pad to run the wire through ! I didn't realize that till too late . Evil or Very Mad
     We don't use the fireplace so I actually mounted my turntable shelf to the brick wall , you can drop a bomb a foot away and no turntable skip .
    Post by deepee99 on Tue Sep 05, 2017 9:05 pm
    pigface wrote:A few years ago I bought a Krell amp to replace my old Carver , I wanted a quality amp for my power hungry Infinity speakers , the Krell manuel said it should have it's own dedicated 20 amp line ! So I actually ran two 20 Amp lines from the box over to where my stereo is kept .  One for the amp and the other for everything else . No hum problem with this set up . It was just a couple new breakers  a roll of romex and a couple quality outlets , also I put a on - off switch on the one line so I don't have to reach around the back of the amp to turn the power switch on . It was just a couple hours work . Although It was a PITA to drill through 5 or 6 inches of cement by the fireplace pad to run the wire through ! I didn't realize that till too late . Evil or Very Mad
    It isn't the bricks so much as that the TT is on a bearing wall, which resonates separately from the floor. End of rumble/feedback. But bricks are good Smile
    For remote switching, consider one of these: https://www.amazon.com/gp/product/B001Q9EFUK/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    It takes a hell of a start-up surge from my s/s/ Bedini 200/200, which doesn't have an on-off switch, without blushing. Haven't tried it on the tubes yet. Pretty cool little gizmo.
      Current date/time is Tue May 22, 2018 11:27 pm
