by Denizen on Tue Sep 12, 2017 12:53 pm
2 quick things. The amps are now on their own table (on top of a huge, slate slab) and a slight bit of hum in one amp was quickly and easily fixed.
As to the hum, Bob was lightening fast with replies so a huge thanks to him for that. In the end, it was simply the ground lug that's bolted down to the power transformer had a bit of soldered wire poking out that made it harder to fit my socket wrench on so I hadn't originally tightened it down as much as I thought I had.
Now with the volume at maximum, I get 42db of hum at each speaker from 1 meter away. For reference, music at half volume is 90db from my listening position (over 3 meters). Damn impressive if you ask me.
I have to say, the amps and Bob's support are everything I hoped for and more. I took a long time deciding on which amp or amps to go for and these spank everything that I was able to audition (Unison Research, Vincent, Cayin and the well respected Ayon).
I'm one very happy camper.
