    New Guy. Chassis Stand
    matallan
    Post by matallan on Sun Sep 10, 2017 11:09 am
    After a long time loitering on this forum, I finally ordered a Vta 120.  Already owe a big thank you to everyone on this form as I have read every post and have learnt enough to be confident enough to build my first tube amp.(Hopefully) While waiting for kit to arrive, I checked voltage in house at varying times and built a dim bulb tester.
     I would now like to build a chassis stand so I will be ready when my kit arrives but not sure if the ones on Google will work for this chassis.  I had thought there was a plan for one on this forum but cannot locate it. I think it was a simple design and only fit the Vta amps. Just curios as to what you are using on your bench
    Re: New Guy. Chassis Stand
    Post by peterh on Sun Sep 10, 2017 11:27 am
    matallan wrote:After a long time loitering on this forum, I finally ordered a Vta 120.  Already owe a big thank you to everyone on this form as I have read every post and have learnt enough to be confident enough to build my first tube amp.(Hopefully) While waiting for kit to arrive, I checked voltage in house at varying times and built a dim bulb tester.
    I do not have my vta70 on a stand, i have it on the top shelf close to the ceiling. That way
    it does not heat other stuff and it's out-of-the-way . As i have build a remote power control
    into the unit i do not have to be able to reach it.
    matallan
    Post by matallan on Sun Sep 10, 2017 11:46 am
    Sorry. Guess I never made my post clear enough.  I would like to build a chassis stand to work and test on the amp upside down
    Post by j beede on Sun Sep 10, 2017 1:14 pm
    I have never flipped a VTA -120 over but I have flipped the VTA-70 many times and it stands just fine without a stand. I suppose the VTA-120 balance may be different. Anyone?
    matallan
    Post by matallan on Sun Sep 10, 2017 3:20 pm
    Perhaps I am over thinking this. I thought the tubes were higher than the transformer so I needed the amp in a stand of some sort so it can be inverted for testing while tubes are still in it
    Dale Stevens
    Post by Dale Stevens on Sun Sep 10, 2017 3:44 pm
    The 120 will lay on its back resting on the transformers That's how I do mine. Dale
    Post by stewdan on Sun Sep 10, 2017 4:04 pm
    Matallan -- The "stand" that you are referring to was shown in Pictures on the Forum, probably 4 years ago???
    I am not really sure of the time frame???
    The Forum Search can't seem to find it now. From what I remember of it, the tubes were higher than the Trannys.
    (Might have been because they were KT120's?????)
    From what I remember, it was a "T-Shape" and the main wood rail fit between the Trannys and balanced out the amplifier.
    Hope this helps!
    Post by Bob Latino on Sun Sep 10, 2017 5:47 pm
    Below are two links .. One shows the dimensions of the ST-70/120 amp stand (NOTE - You will need TWO PIECES of the dimensions shown) and one shows what it looks like in use.
    https://www.facebook.com/vta.amp.kits/photos/pcb.1048613525247177/1048613175247212/?type=3&theater
    https://www.facebook.com/vta.amp.kits/photos/pcb.1048613525247177/1048613115247218/?type=3&theater
    matallan
    Post by matallan on Sun Sep 10, 2017 8:37 pm
    Wow. Thanks. I appreciate that. That's the one I had seen a while back. Waiting on some parts so I will make one up.
    wildiowa
    Post by wildiowa on Sun Sep 10, 2017 9:58 pm
    This seems similar to the "rotisserie" that we would sometimes build to work on restoring old VW's. Put the body on that thingie and rotate it for painting etc...also used one for painting old guitars. Great idea. You can probably get by without one for your amp.
    Post by deepee99 on Mon Sep 11, 2017 1:14 pm
    Troy Madden built a nice little stand for construction and bench work. He put up some photos of it a few years ago on the forum. I can't remember the thread, Bob L., maybe you do?
    aguaazul
    Post by aguaazul on Tue Sep 26, 2017 10:51 am
    I was at a client's job site yesterday and had them cut up the plywood for me. my question is what do you place in the 3/16th hole? Do you use the screws that came with the amp or wood screws?
    Then the screws / washers to secure the top, what do you use there?
    Thanks, Blue
    Post by Bob Latino on Tue Sep 26, 2017 11:05 am
    aguaazul wrote:I was at a client's job site yesterday and had them cut up the plywood for me. my question is what do you place in the 3/16th hole? Do you use the screws that came with the amp or wood screws?
    Thanks, Blue
    You will need four 6-32 machine screws 1 inch long. The 6-32 machine screws fit into the 4 tapped threads on the main chassis that presently hold on the bottom cover of the amp.
      Current date/time is Thu Apr 26, 2018 6:54 pm
