Hi everyone. I'm restoring a pair of Dynaco mk II amps, and just have a few questions. Though I have built a number of tube guitar amps, I'm not very experienced regarding electronics, so please go easy on me...
My first question is re. the diode - will a 1N4007 be an acceptable retrofit?
Next is the 12 ohm bias resistor - as I have a set of simple octal bias probes, will these not obviate the need for installing them? ...and might I assume a 60% pd figure for a set of JJ E34L's operating in this environment to be reasonable?
These amps came to me with the original speaker terminal strip having been replaced with a simple set of red/black speaker screw terminals. As the owner has (and will use exclusively) a pr. of 8 ohm speakers, am I wrong in thinking that I would connect the black OT lead to the black (neg) terminal, then the orange (8ohm) secondary to the red terminal (which then connects to eyelet 7 on the pc board) with the 680 ohm resistor bridged across the 2 speaker terminals?
I hope I was clear enough here, and thank you in advance!
Chris
Chris
